SG-TP-AB RS230 - Timeline
  • #61
    We Posti tap'ed my Mates Golf R, seems fine.
    I had ordered plugs from Audi (lambda side) and wire with pins, and also ordered the ECU side from china before I'd really worked out what the go was.
    China sent 4pin not 5pin plugs, so have to wait a week (ex UK).
    I think a few have done what Im trying to do, but its not cheap.... $115 for a plug and 5 wires/10 pins attached....
    Skoda RS 230
    "The Grey Ghost"
    • #62
      Originally posted by HPRS230 View Post
      JB4 installed....
      Awaiting the Lambda Plugs to hook up AFR, then off to the Dyno
      Can you please keep me posted on how the JB4 goes. I may be looking at going down that avenue sometime this year
      • #63
        Mate You want it!
        4.5 psi extra then full custom after that.
        PM dugson if you are keen now, he has one going for what a very good price..
        Skoda RS 230
        "The Grey Ghost"
        • #64
          Ferrert had time today to cut the blanking plates in the grill, so now we have the full Ferret airbox mod
          Skoda RS 230
          "The Grey Ghost"
          • #65
            Starting to plan whats next for the RS230 ..... but the 'minister of finance' has cracked it, so everything is on hold till march/April.
            Planning to order:
            Internal TPMS - TICK
            DashCam
            A huge Superskoda order
            Maybe Track wheels and tyres.
            Im keen to get the RS230 rims from superskoda, but will most likely go with some 2nd hand wheels locally
            Skoda RS 230
            "The Grey Ghost"
            • #66
              TPMS ordered..... Should have them installed this weekend
              Skoda RS 230
              "The Grey Ghost"
              • #67
                So had a bit on this week.
                - Meet up with Spinifex to enable Video in Motion. Now I have to work out if I need to buy the JB4 wireless kit to display the gauge set...
                -TPMS arrived today, so got the sensors fitted at Toombul Bob Jane for a box of Beers, If you need anything to do with tyres, make sure you go there, I've been using them for 5 years!
                - On the Way home this afternoon, I hit 3000km.
                - Once home, mounted the Display and ran the RF wires.
                - 1 wire along the plastic sill cover and up the to rear door
                - the other behind the dash and in to the engine bay by the left front head light.
                This should give it a good signal.
                Off tomorrow to get a Fuse Tap and run 12V behind to the drop down bin above the drivers knee, so the TPMS has power.
                I've got an 4 way ciggy box, so will mount that inside.
                I was gutted to find the fuse box is not on the ends of the dash like I had read on Briskoda, but this will still work fine. Just have to run a longer cable.
ID:	1826453 Click image for larger version
ID:	1826454 Click image for larger version
                Skoda RS 230
                "The Grey Ghost"
                • #68
                  Set the Cold Pressures very early this morning.
Name:	Cold TPMS Set.jpg
                  Bit disappointing that its not really 0.1 PSI, more like 0.3/0.4 PSI.
                  So cant really get them all the same.
                  Skoda RS 230
                  "The Grey Ghost"
                  • #69
                    So after shopping around, I got all the bits I needed to install the ignition power to the drivers side.
ID:	1826472 Click image for larger version
ID:	1826473 Click image for larger version
                    On a side note,
                    I think I've seen a couple of other RS230's around Brisbane, by only looking out for the black pipes....
                    Wish they were easier to see
                    Skoda RS 230
                    "The Grey Ghost"
                    • #70
                      [ATTACH=CONFIG]27847[/ATTACH] [ATTACH=CONFIG]27848[/ATTACH] [ATTACH=CONFIG]27849[/ATTACH]
                      On a side note,
                      Won't help you with mine haha
                      • #71
                        Did some testing of the JB4, Stock/Map 1 & Map 2, and emailed to BMS, he was happy with the results, buts once I get the Lambda plugs I shall re test to see if the AFR are better, currently a little rich for my liking, but thats ok, rather that than lean....
                        As we have a Track day coming up, Thought I'd be safe than sorry...
                        So Popped in to Bunnings for a 1kg Fire Extinguisher (Dry Powder $15.80)
                        Installed with Cable ties in the boot via the cargo net hooks, seems to hold up for a lap around the block.
ID:	1826497 Click image for larger version
ID:	1826498 Click image for larger version
                        Skoda RS 230
                        "The Grey Ghost"
                        • #72
                          Got my wireless jb4 kit today, installed at work! Looks good.
                          Also got my lambda plugs from the UK, so made up a little jump loom.
                          And dyno booked for Wednesday
ID:	1826521Click image for larger version
ID:	1826522 Click image for larger version
                          Skoda RS 230
                          "The Grey Ghost"
                          • #73
                            As well as sorting out the above, I've ordered a DTE pedal box thingy.
                            Should have by Friday, fingers crossed....
                            Pedal Remap - PedalBox: increases throttle response
                            Skoda RS 230
                            "The Grey Ghost"
                            • #74
                              hey mate I also have the JB4 on my 16 VRS TSI. Did you get the display to come up on the Columbus?? How did u do this apart from the wireless unit? I thought it was only an app on android / iphone? Or are you using Mirror Link? Whenever I try and use mirror link on my android it always says no compatible apps found...
                              • #75
                                [ATTACH=CONFIG]27901[/ATTACH]
                                [ATTACH=CONFIG]27902[/ATTACH]
                                [ATTACH=CONFIG]27903[/ATTACH]
                                [ATTACH=CONFIG]27904[/ATTACH]
                                Nice work!
                                MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
                                Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
