timing belt
  • timing belt
    Hi All,
    I've got a 2008 Octavia RS TSI manual, with 92,000km. It's due for a 90k service, and I'm wondering if I should get the timing belt done. The handbook says 180k and the dealership quotes 105k, not sure which is right but I'm guessing the 105k. Anyway, as it's 8 years old should I be getting it done, as well as the water pump? Cheers for any opinions/advice.
    It's been dealer serviced up until now, but I'm gonna switch to an independent from now on, so am happy to get any recommendations. And does anyone know the cost of an OEM timing belt kit, or should I source one ex UK or whatever?
    now: 2024 Cupra Leon V
    '70 Alfa Romeo 1750 Berlina - project
    before: 2008 Octavia RS TSI manual sedan, sprint yellow, Stage 1 tune, 185kw.
    Probally save yourself and would be easier to source via UK/Europe (Super Skoda)?
    2018 Superb Sportline 206 Moon white sedan
    2018 Kodiaq Sportline moon white Diesel ( Wifes car)
    2016 Octavia wagon VRS Race Blue, black & tech pack (Sold 08/19)
    1966 Alfa Romeo Gulia Sprint gt 105
      105,000km is the normal recommended interval for the timing belt, and you should also replace the water pump while you are at it.
      Places like ECS Tuning (based in USA) sell the timing belt kits with all the bits you need, but Euro Revolution in Sydney are a reseller for ECS so you can probably order everything you need from them. Euro Revolution - Euro Revolution
      B9 Audi SQ5
        105K or 7 years.
        As per above, do the water pump and pulleys as well.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          The water pump got included as part of that belt replacement a while back. The belt should have been done last year. Ours had done 60k but 7yrs came up in November.
            It's a curious thing, because the dealership has done several services, including the 75k last December when the car was 7 years old. They mentioned nothing about the belt being due for replacement, and I actually asked them when it was due and they just said 105k with no mention of the 7 year timeframe. You'd think they would have mentioned it, because if the belt had failed I'd have had a good case to argue they were negligent.
              Which dealer? It was originally even earlier, but I find some are hopeless with this sort of thing. I had always intended to get the waterpump done as well, but when they did it, it turned out it was included now. I knew it was due, so maybe unless you bring it up they don't keep an eye if its not up to 105kms.
                I did my TDI myself using a kit from the UK (maybe from eBay I think). Cost about $150 for the kit (didn't include water pump) and $50 for special tools. That was a couple of years ago. If you're a reasonable home mechanic and have a decent set of tools it should be able to be done over a weekend. Once you get the hang of it in a day (problem is you'd forget the process by the time it needs doing again).
                I'm just doing one on a Camry now. I can't believe what mechanics charge for doing this it ain't that hard.
                2008 Skoda Octavia Elegance TDI 4x4 wagon
                Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
                  8 yo car..
                  If it's a keeper, get the belt/pump done now
                  Purchase kit online (ECS or the like)
                  Find an independent specialist who is ok with fitting parts you supply
                  Some dealers don't tend to acknowledge non scheduled parts replacements that have proven to be required. Independent specialists tend to adapt based on what they see present to them over time and recommend accordingly...my experience anyway...
                  2006 VW Golf GTI Silver Mk5 5dr manual no options (the way nature intended) SOLD
                  2012 Skoda Octavis RS wagon, race blue, red stitch interior, DSG SOLD
                  2008 Skoda Octavia vRS Wagon (Mk II, pre-FL) 2.0 TFSI 147Kw 6 MT bright yellow SOLD
                  Other: 2013 Mercedes B250 Sliver Command Pack panoramic roof
                    The Camry is notoriously easy, the local Toyota dealer have specials on it for under $200 all up from memory, it shows in the local paper all the time. Far cry from the $1k the Skoda dealers charge, but I think there is a bit more involved compared to a Camry.
                      VW/Skoda allow 4-4.5hrs to do a timing belt.
                      Be thankful it's not a B5 V6 Passat
                      '01 Beetle 2.0
                        I did one in the original TT Quattro once, at the same time as a clutch, I was nearly in tears
                        Main Dub:
                        2010 Crafter Hanover Bus
                        1956 Type 1
                        2015 vRS wagon black on black
                          My condolences.
                          They're a cow of a thing to work on at the best of times.
                          '01 Beetle 2.0
                            I've got a quote from a local independent mechanic who specialises in euro cars. He's been recommended. He's quoted $250 for a 90k service, and approx $880 to supply and fit timing belt, tensioners, water pump etc. He sources quality after market parts for the belt kit, but uses OEM dealer sourced water pump as he said in his experience all of the after market water pumps tend to leak after a year or two.
                            I'm not confident enough in my own ability to tackle the job myself.
                              That's a keen price.
                              '01 Beetle 2.0
