Originally posted by Lucki
View Post
MK3 Octavia - List of Defects, Faults and Issues
Good advice Dzi_Dubba. I had same issue as Lucki and had the water pump replaced at 15000km service a few weeks back. Checked levels again on Monday and noticed level was near minimum mark again. Took it to the dealer the next day (thinking they hadn't tightened one of the hoses properly) and service manager opened the reservoir cap and level went up to normal again. Sounds like a fairly common occurrence with the new RS.
Hey guys,
Yes I did open the reservoir first thing in the morning and the level was very low, much lower than the minimum mark. Hence the warning.
Anyway took it to the dealer and they have topped it up for free. I've been keeping an eye and no leaks that I could see so that's good.
A good mate of mine is senior VW mechanic, apparently the water pump issue is a pretty common issue which runs across all the models with the 2L engine in the VAG family. Not sure what/how they're treating the issue besides warranty claims, my guess they're treating it as each issue arises...Originally posted by woofy View PostBit concerned how many water pumps you guts have had replaced early on. That's not a minor thing.
It was an issue with the MkII something to do with a plastic impellor or something. I never saw it but was always warned to replace the waterpump when the belts get changed in case. I had hoped 10 yrs on this issue would be gone by now but seems either the same one, or something worse.
The water pump on our 8 year old VW Transporter van 1.8 TSI was replaced last month at 200,000 km. Caused vehicle to be towed. First time off road due to mech failure. Bit of plastic within the pump failed.Last edited by afterdarker; 01-06-2015, 03:00 PM.
I had this problem with my VW Mk7 Golf GTI Performance within a not dissimilar timeframe from receiving it new and it turned out to be a crack in the water pump which they replaced (under warranty obviously).Originally posted by Lucki View PostHad a 'Check Coolant' warning on the dash this morning and upon checking the reservoir, the level was below the minimum mark. Rang the dealer and they offered a free top up whenever I could drop in.
My vRS is less than 3 months old and done just 3000KM. I'm thinking the dealer didn't do their PDI properly, considering the poor condition of paint when the car was delivered. But I am also going to keep an eye just in case there is a leak somewhere.
Anyone else had this problem? Is it normal for the coolant to run out so quickly? Thanks!
Had this at about 10000km. Added 250mL water and it's not recurred. Will get the system checked at first service this week.Originally posted by Lucki View PostHad a 'Check Coolant' warning on the dash this morning and upon checking the reservoir, the level was below the minimum mark. Rang the dealer and they offered a free top up whenever I could drop in.
Had a couple of drives where the SatNav has failed to initialize - can't find a Satellite? Amusing that the guidance system gets lost.
I just had low coolant warning (red triangle message) at 21000km, checked the expansion tank and it was well below the minimum. Dealer ran few test and found a small leak in the radiator. It was only detectable once the engine has warmed up. Didn't mention anything about the water pump.2011 Tiguan 125TSI - SOLD
