mirrors only dip if you have memory seats, which the rs does not have (only elegance/style).
OCTAVIA III Owners discussion thread
2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
I've got the same vehicle and i can see the media that is playing when sat nav is on. You have to turn on split screen in the options. Then tap on the media button. Trust me, it's there as i use it already. No mods or anything. Factory feature.Originally posted by jai View PostI'm finding it a tad annoying on MY15 RS that when you're on sat nav mode, there is no reference to the radio station when changing, so you don't know where you're up to. You need to change your dash to view your media, then you can see it. There is plenty of room along the top of the main screen for a small bit of info like this. My rear view mirrors also do not dip on reverse, even though the option is ticked. Other than this, no complaints !MY15 VW Golf R | White | Manual
MY15 Skoda Octavia RS 162TSI | Liftback | Race Blue | DSG | Tech Pack (w/o RVC) | +2 Years Extended WarrantySOLD
RS with comfort pack comes with leather memory heated seats and folding, dipping mirrors.
Originally posted by GTR27 View Postmirrors only dip if you have memory seats, which the rs does not have (only elegance/style).Walking Contradiction...
MY15 Skoda Octavia vRS 162 Race Blue Combi
Exactly what he said.
Originally posted by Reichter View PostI've got the same vehicle and i can see the media that is playing when sat nav is on. You have to turn on split screen in the options. Then tap on the media button. Trust me, it's there as i use it already. No mods or anything. Factory feature.Walking Contradiction...
Thanks for the info. I've looked in media and nav options and can't see anything in relation to split screen? Would you be able to share the button sequence to get to split screen please? Thank youOriginally posted by Reichter View PostI've got the same vehicle and i can see the media that is playing when sat nav is on. You have to turn on split screen in the options. Then tap on the media button. Trust me, it's there as i use it already. No mods or anything. Factory feature.
When you hover over the NAV screen you'll see the menu bar at the bottom. Click on the option that says 'View' and select from the list of check boxes and the split screen will appear.
Originally posted by jai View PostThanks for the info. I've looked in media and nav options and can't see anything in relation to split screen? Would you be able to share the button sequence to get to split screen please? Thank youWalking Contradiction...
Took my key to dealer and told them key was dead. I have KESSY system. Garage key which sits with my house keys drained battery from KESSY key. They replaced free of charge. Keys sit in same pocket hence the drain but now they don't. They were never on the same key ring either. Car key always separate.[FONT=Franklin Gothic Medium]Matt
2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
I need to check but I'm sure I'm 19x8.5 et35, stock height tdi rs and no rubbing. Same tyre size as stock 19s.Originally posted by GTR27 View PostHave a read on briskoda, but from memory, the rear can take a huge rim.
In my searching, I think 8.5" with ET35 was OK for rubbing front and rear, but I'm pretty sure the rear you could get away with 9.5" on a lower offset and still not rub unless it was ridiculously low.Sorry. Don't know why it always puts my pics upside down...
Anyway to activate the deadlock from the keyfob? Mine doesn't have the alarm and you can lock the car on the fob and still open the doors from inside. Bad if your car is black like mine and want to crack the windows a bit to vent the sauna...
I think by default 'safelock' is enabled - when you lock the car the inside should lock. If you press the lock button on the fob again (within 2 seconds) it cancels 'safelock' and the inside is open.Originally posted by ozgti View PostAnyway to activate the deadlock from the keyfob? Mine doesn't have the alarm and you can lock the car on the fob and still open the doors from inside. Bad if your car is black like mine and want to crack the windows a bit to vent the sauna...
If you have an alarm, yes. If you don't have an alarm, there's no safelocking optionOriginally posted by gamcem View PostI think by default 'safelock' is enabled - when you lock the car the inside should lock. If you press the lock button on the fob again (within 2 seconds) it cancels 'safelock' and the inside is open.
