RS Eibach lowering springs (family wagon)
 Eibach Skoda Octavia (1Z5) Estate 2.0 TDi Pro-Kit (E10-79-004-04-22)Originally posted by donweather View PostYup please!!!
 Delivery to Australia is about $80. I have sent them an email enquiring about stock availability and delivery times.-----------------------------------------
 Mk7 Golf GTI PP DSG, Tornado Red
 Lowering springs alone are good for posing and cornering on very smooth roads. You need DAMPERS that are matched to them for improved control (stock ones may work sort of OK for a while but the higher spring rate WILL kill them much more quickly than they would last with the OE springs).Originally posted by donweather View PostSo for those that have the Eibach lowered springs with stock shocks, can I ask, do these lowered springs assist in anyway with more front wheel traction/less axial tramping etc, or are they purely for handling (cornering)?
 As stated by others in this thread alone
 Originally posted by Martin View PostI used lower springs on stock shocks, the out come was hard and unstatisfactory
 I switched to Eibach springs and Bilstein shocks - wonderful solution (back to factory ride height)Originally posted by fred27 View PostIt is not the spring alone that affects the ride. Important to remember that the spring needs to be matched to the shock. I'm using the Eibach pro (springs and shock kit bought from Eibach Australia). Lower, good handling and supple ride.Originally posted by Mysticality View PostI have the VWR springs, and they make a difference in cornering, but undulating country roads now feel horribly floaty and scary, when they used to be able to be taken with confidence... But new shocks will *probably* solve that.Resident grumpy old fart
 Thanks. I had seen them before and didn't think it really was worth the hassle of an international order to save AUD$50-$60Originally posted by MrGadget View PostEibach Skoda Octavia (1Z5) Estate 2.0 TDi Pro-Kit (E10-79-004-04-22)
 2012 Yeti 77TSI, Candy White
 ydad.com.au: musings of a dad growing up - the blog.
 cbay.com.au: photography, video, design - creations.
 No...Mine still has the worst axle tramp under very heavy take off!Originally posted by donweather View PostSo for those that have the Eibach lowered springs with stock shocks, can I ask, do these lowered springs assist in anyway with more front wheel traction/less axial tramping etc, or are they purely for handling (cornering)?
 Just ask Mysticality...he has driven with me.....2018 Ralyee Green RS wagon. Fully optioned.
 I wouldn't call it the *worst*... The diesel engine is heavier than the petrol, but it is pretty bad.Originally posted by Tigger View PostNo...Mine still has the worst axle tramp under very heavy take off!
 You need to get a whole front end suspension makeover! Pronto! 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 Not including hers...
 They are primarily for looks, they will reduce roll somewhat and give a more sporty rideOriginally posted by donweather View PostSo for those that have the Eibach lowered springs with stock shocks, can I ask, do these lowered springs assist in anyway with more front wheel traction/less axial tramping etc, or are they purely for handling (cornering)?
 When pushed hard on less than favourable roads you may hit the bump stops - this is highly undesirable (and can be dangerous)
 (Our standard shocks are nothing to write home about - I love the control of my Bilstiens)
 These springs won't make any difference to axel tramp
 You either need a firmer dog bone mount or the Supaloy control arms
 The dog bone mount has terrible/negative consequences (loud and low frequency cabin reverberation) at idle, in stop/start traffice and when reversing - I went back to stock!
 The Supaloy control arms are a tad expensive but solve axel tramp, provide better straight line stability and more negative camber which increases corning road holding - given the benefits these are good value for money in my opinion2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
 Good luck on getting this message through (plus the jouncy, floaty experience on bumpy roads) - I've tried on multiple occassions.Originally posted by Martin View PostThey are primarily for looks, they will reduce roll somewhat and give a more sporty ride
 (Our standard shocks are nothing to write home aboutResident grumpy old fart
 do the whiteline kits do all that too?Originally posted by Martin View PostThey are primarily for looks, they will reduce roll somewhat and give a more sporty ride
 I get axle tramp and it pops open the dash hidey-hole which is really distracting. also the actual tramping is bad too
 ok checked out their site. they look great! martin, which ones do you have?
 From all reports, the WALK will have a similar effect to the Supaloy control arms since they both reduce the stiffness (increase compliance) of the front suspension to dive/lift so the suspension doesn't bind up from the geometry in these circumstances.Resident grumpy old fart
 Martin got the full arm which includes the rear bracket.
 BTW: Martin - half an insert is pretty good. I think if they were a lower duro they'd be pretty good all roundcarandimage The place where Off-Topic is On-Topic
 Thanks Martin.Originally posted by Martin View PostThey are primarily for looks, they will reduce roll somewhat and give a more sporty ride
 I am looking at getting the Eibach springs and the supaloy control arms so hopefully that improves the look and feel (axle tramping) of the car, particularly if I also decide to go for an ECU upgrade.
