Originally posted by brad
									View Post
Bluefined my 2012 VRS Octy
 I really don't know.
 Maybe google "sticking VNT turbo vains"?
 You might also talk to your Bluefin retailer. They are usually anxious to help.carandimage The place where Off-Topic is On-Topic
 Could be a failed cat and its blocking the exhaust flow. Could also be a failed o2 sensor of course.
 Should either of these be covered under warranty? Even with a bluefin? I assume it would be hard for the Skoda Dealer to prove that a bluefin caused either of these failures (but I'm pretty sure they'll still try!!!)?Originally posted by Lucas_R View PostCould be a failed cat and its blocking the exhaust flow. Could also be a failed o2 sensor of course.
 It will depend on the individual dealership mate - but luckily both items are cheap. The o2 sensor would be around $100 or so, and if you have a failed cat, you could have an exhaust shop remove the dump pipe and remove the obstruction.Originally posted by donweather View PostShould either of these be covered under warranty? Even with a bluefin? I assume it would be hard for the Skoda Dealer to prove that a bluefin caused either of these failures (but I'm pretty sure they'll still try!!!)?
 Failed cat = good opportunity to fit SPM downpipe & 200 cell cat.
 edit: Give APR or one of the tuners a call as they probably have old OEM DPs & cats hanging about or in the scrap bin.carandimage The place where Off-Topic is On-Topic
 I'm not that keen to modify the DP to be honest. And I would have thought these failed components would be covered under warranty with or without a bluefin.
 Given that the warning light has gone out and assuming it came on due to one of the above failing, what would happen of I did nothing (ie don't replace anything)?
