Skoda Mentone said to give it a polish and it'll do away and yes the oxidation has gone but the colour mismatch is still there and they won't do anything about it cause they say its due to the plastic compared to the metal panels???
That's crap and it's nothing to do with them anyway it's a Skoda Australia problem. If they had even one once of interest in customer service they would have referred the issue to Skoda.
My advice. Go to a dealer who is interested in supporting their customers.
First issue - Tow bar control unit - was faulty from the first time i used the RS to tow a trailer and also the ECU hadn't been re-coded ( nil canceling of the reverse sensors when a trailer is fitted) , got screwed around with the guys at Steve Jarvin ( where I bought it from ) but decided they were going to replace it because it was stuffed. Before they got the part in they were forfeiting their franchise so I took it to the Newcastle service centre ( Audi Newcastle), they checked it out, control unit was fine, was a blown fuse and that the control unit was a south american model. Also they re-coded the ECU and all was fine except for a blown bulb function due to the S/American model working slightly different. New Control unit fitted now. All done under warranty
Issue 2 - Roof lining where it meets the windscreen was not seated correctly ( seemed to be too short ), was refitted but still not correct so a complete new roof lining was ordered and refitted - all good - all done under warranty.
Issue 3 - Drivers seat mesh was pilling, seat cover was replaced, not under warranty but under good will through Audi Newcastle/Skoda Oz - was very happy with that outcome, considering I did find out that the wife had been wearing pants with velcro tabs on her rear pockets - I found that after getting the seat cover changed, I felt a little naughty getting it repaired for nothing when i found out
Issue 4 - Front bumper/spoiler paint had bubbled and started to lift in the very corners of front number plate recess - has been inspected and will be repaired/resprayed when i take it in for it's 30,000km service later this month. Again will be done under warranty.
Considering I didn't buy my car from Newcastle Skoda, the service centre has been brilliant - they jump on the phone to Skoda Oz with no hesitation and always work on a best solution for all ( so far that has all been in my favour ). They're even very clued up on good set up for the Skoda's - I had my wheels re-aligned after a little sawtoothing on the rear wheels, they did a very acurate job & set it up so it doesn't effect camber so much when loaded up, but not so much that it effects unloaded driving - so far the tyres have worn very even since the alignment. They even are keen to have a chat about other set ups with suspension and possible engine "tweaks" I've been considering.
All in all, nothing major, just a couple of annoying faults but were quickly addressed and looked after under warranty etc. Am very happy with the car & the after sales service from Audi Newcastle - Skoda S/centre!!
Overall v.happy with my pre FL Octavia vRS but since you ask....
Warranty issues:
1/
Air conditioning compressor failed - replaced under warranty
2/
Rear boot strut mount collapsed and has scraped paint due to rubbing. Booked in to fix under warranty
3/
Rubber surround around hand brake lever has bunched up making it harder to take the hand brake off. Booked in to fix under warranty
Other quirks of the car I've noticed
1/
Door seals creak when entering or exiting driveway
2/
Air conditioning fan 'flutters' intermittantly as others have described
3/
Creak in front suspension when going over speed bumps at very low speeds (should I have this checked out?)
2006 VW Golf GTI Silver Mk5 5dr manual no options (the way nature intended) SOLD
2012 Skoda Octavis RS wagon, race blue, red stitch interior, DSG SOLD
2008 Skoda Octavia vRS Wagon (Mk II, pre-FL) 2.0 TFSI 147Kw 6 MT bright yellow SOLD
Other: 2013 Mercedes B250 Sliver Command Pack panoramic roof
My RS wagon is 7 weeks/4,000km old now, and only a couple of minor annoyances.
When the car was about 2 weeks old I found a screw on the front passenger floor, which no doubt came out from under the dash somewhere. It's since developed a nasty squeaking noise coming from around the glove box area. I think it's the glovebox base. Haven't really had time to investigate where the screw came from, and Richmond Skoda have said to bring it in and they'll look at it.
When using the aux jack in the console with my ipod, a couple of times I've selected 'media' on the head unit and it hasn't recognised the ipod. And on one occassion when I selected media it just permanently displayed "starting system" and nothing actually started.
Also when I turn the car off, the MFD displays a warning saying "check safety locking" or something like that (can't remember exact words). I haven't gotten around to reading the manual to see what this means. It's done it since new, maybe it's normal?
And I've noticed that sometimes the rear cargo screen seems to rattle a bit. It's intermittent, and if I retract it and slide it out again it'll often stop rattling.
But otherwise I'm very happy with the car.
now: 2024 Cupra Leon V
'70 Alfa Romeo 1750 Berlina - project
before: 2008 Octavia RS TSI manual sedan, sprint yellow, Stage 1 tune, 185kw.
Wow - a few problems around. We have an RS wagon with 16000ks and no broken bits (touch wood).
I had the back wiper fall off (it just slides in, but it looks like its broken so I left it off and asked them to look at it at service) - I might add that NMG tried to charge me $30 to replace it at the service. $30 for 10 seconds of time seems a bit steep and no one asked me so I cracked it and he knocked it off the bill as requested. Many service centers try to charge you for replacing wiper blades these days - highway robbery.
Also had a squeak around the the A-Pillar near the dashboard. Nothing a bit of spray lube couldn't fix.
Make sure that the cable is fully inserted into the jack
I suspect that's a set up issue with the MFD. Just go into the MFD options and look at the door lock settings.
Dazag
How do you manage to get warranty done at an Audi dealer?
I wanted my N75 issue looked at by a conveniently located, local VW/Audi dealership & Skoda said tough luck - have a day off work & attend a Skoda dealer. Unless I get another dealer able to do warranty that is convenient to work (Campbelltown, NSW) then I doubt I'll buy another Skoda.
carandimage The place where Off-Topic is On-Topic I used to think I was anal-retentive until I started getting involved in car forums
Brad - As Kiwi said, the Newcastle Audie Service Centre looks after both Audi & Skoda with regards to servicing ( although separate show rooms) , and these guys know their stuff. I rate these guys - They give me a courtesy car free of charge ( another Skoda ) for the day, they text me the day before reminding me of any bookings I've made. They call me as soon as any warranty parts or parts I've ordered have come in to make a booking to fit them. Their customer service is spot on in my books.
Got mine via a novated lease and the lease coy said that any "registered" mechanic could service the vehicle.
That's the legal position regarding warranty coverage but that does not mean that an individual workshop has to service the vehicle if they don't want to and many Audi/VW workshops won't service Skodas.
After having to get the drivers door reattached in the correct spot, have the harmonic balancer and drive belts replaced and the generally piss poor interior/panel quality of my 8,500km old VE2 SSV I was thinking of getting an Octavia instead, hoping the quality issues wouldn't exist. This thread makes me sad lol. My Holden dealer has been surprisingly good, though. Which is... surprising...
The RS I test drove earlier this year had a fluttering sound from the passengers side AC vent. Sorta as if there was some paper stuck in a fan.
Car/source of annoyance: Sept 2010 S2 VE Commodore SS-V Redline Edition m6
Well I hope this thread doesn't deter prospective buyers away from the Octavia's. We've had our RS for 4 months now and done 9,000kms - not a single problem at all. Runs absolutely fantastic.
Used to own a BF XR6T and the quality is such a huge difference...get a Octavia SSVR and you won't be disappointed
