So far have done the following on our new Kamiq.
Rear tails on with DRL
Module 09
Leuchte 24SL HRA 69
Leuchte func C 24 alter to Tagfahrlicht
Dimming CD 24 change to 5 Press & Hold to set the change
Leuchte 23SL HLC7
C23 alter to Tagfahrlicht
CD 23 change to 5 Press & Hold to set the change
Leuchte 20BR LA70
E 20 change to Tagfahrlicht
EF 20 change to 5 Press & Hold to set the change
Drl's off with handbrake
App on OBDEleven
Dial staging
Module 17 Dashboard
Long coding
Staging change to YES Save change DOESNT WORK On Kamiq
Dynamic High Beam Assist
Module 09 Central Electrics
Adaptations
Fernlicht Assistant
Expanded High Beam Control
Change to AFS,FLA,Fernlicht ueber AFS
Menuesteuerung Fernlichtassistent change to Present
Menuesteuerung Fernlichtassissent Werkseinstellung Change to Present
Save Changes.
Module 09
Leuchte 24SL HRA 69
Leuchte 23SL HLC7
Leuchte 20BR LA70
App on OBDEleven
Dial staging
Module 17 Dashboard
Long coding
Adaptations
Fernlicht Assistant
Save Changes.
