I just read your latest update last night and was going to ask you what parts you needed replacing.
If its the upper control arms then these should be the replacements (theres 2x on each side):
034 - Density Line Upper Control Arms, Audi B8/B8.5 A4/S4 & A5/S5/RS5– VAGPARTS Australia
Engine mounts id get OEM replacements for $1,295 unless you can find cheaper.
Not sure what the front buffer torque mount is referring to?? This might be the transmission mount? Its just a tiny piece of rubber so not worth shopping around as $95 is cheap enough.
Rear centre diff bush. Suprised this is worn out. I would fit an 034 Motorsports insert to see if this buys you some more time. The034Motorsports insert reduces the movement in this bush (i have one on my car) 034 - Billet Aluminium Rear Differential Mount Upgrade, Audi B8 & C7 Series– VAGPARTS Australia
If you do the 034 diff mount, then you might want to consider this kit which offers transmission mount bush, diff carrier bush and diff mount. I have this in my car and it just tightens everything up nicely without any NVH or vibrations.
034 Motorsport - Drivetrain Mount Insert Package, Audi B8 A4/S4/RS4, A5/S5/RS5– VAGPARTS Australia
