If it doesn't already have one a reversing camera is a bit of a must in these. While you're there you might as well also upgrade the head unit to something which supports CarPlay/Android auto. These are little things that don't impact the performance but make life much much nicer inside. (And are also cheap and very DIY friendly).
Thanks for the reply mate
Already purchased and installed a RCD330+
Also purchased a reverse camera, just need someone to install it for me
I think I need someone to VCDS my head unit cos only the two front speakers are working, and I googled the issue n they said it's gonna be enabled via VCDS coding
2015 Trendline only had 2 front speakers installed from the factory, unless you (or the 1st owner) paid extra for the 6 speaker system when it was ordered. Typically those with the RCD310 as stock had 6 speakers and those with the RCD210 only had 2.
Current:2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSIRed (tuned over 200kw + lots of extras) 2013 Up! manual Red2017 Polo GTI manual Black Previous VWs and some others ...
Also, you could open up the rear speakers and see if there is actually a speaker in there.
