MK3 manual gearbox
  • QLD MK3 manual gearbox
    My beloved 1997 MK3 Cabrio 2l petrol AGG manual 5sp gearbox has disintegrated so, first...has anybody got a spare one? and secondly......is there an alternative that fits?
    I’ve got a 1.8 gearbox here. I think they are more or less the same.
    $100, only removed because of engine swap. Worked perfectly fine.
    Located Newcastle NSW will post
      Tks, not sure about ratios etc...can anybody else advise?
        Further to previous, my cabrio is AGG, the 1.8 codes are as follows showing gear ratios, any look familiar??
        Gearbox codes/Ratio’s
        Code Type cc code Speed Dates 1. 2. 3. 4. 5. Final
        APW 020 1.8 ABS 5 11/91 - 07/92 3,455 1,944 1,370 1,032 0,850 3,667
        CHB 020 1.8 ABS/ADZ 5 08/92 - 04/96 3,455 1,944 1,286 1,032 0,850 3,667
        CHD 020 1.8 ABS/AAM/ADZ 5 08/92 - 04/96 3,455 1,944 1,286 0,909 0,745 3,667
        DFN 020 1.8 ADZ/ANP 5 05/96 - 05/96 3,455 1,944 1,286 1,032 0,850 3,667
        DFP 020 1.8 ADZ/ANP 5 05/96 - 05/96 3,455 1,944 1,286 0,909 0,745 3,667
        DFQ 020 2 AGG 5 08/97 - 3,455 1,944 1,286 0,969 0,805 3,667
          Where are you located. I have an O2O gearbox out of a 1996 Golf 2.0 and an O2A out of a Seat Ibiza Cupra.
            Brisbane....what's the history of the 020 and the code stamped on the housing??
              Do you have a phone number? (or email me on 'briant0007@optusnet.com.au'
                I sent an email with photos. Hopefully you got it.
                  Interested if you still have the mk3 5 speed. I have a 2L mk3 making horrible gearbox noises , stamp on gearbox is 020 and its a cable clutch arrangement, limited knowledge of vw past that. Also in newcastle so cam pick up
