Had an oil leak due to faulty oil filter installation. Oil fell from the oil filter onto the alternator directly below and a belt also located vertically below the oil filter. I am not sure what the belt does but it is making a "screeching" sound in tune with the engine rpm (it increases in pitch as engine rpm increases).
What are my options to stop this? I used a degreaser in the engine bay which cleaned up most of the oil residue and also put some on the belt then washed it off but the noise remains albeit reduced. Should I keep using the degreaser or is there nothing else I can do?
Suggestions welcomed.
