DSG & neutral with handbrake
    Just to confirm that Auto hold does keep car still when stopping facing downhill.
    'Tried it today and car just sat there for about 3 mins until I tapped the pedal and it then rolled away
      Just an observance with our Transporters DSG in relation to stopping at lights etc , in ours if you watch carefully at the Tacho when the brakes are applied at stop the tacho fluctuates up a tiny number of revs . As soon as you release the brakes its as if it is engaging again and the tacho decreases as it takes up the load .
        Yes because both of the clutches disengage just like if you put it into N and the 1st gear clutch engages when you release the brake
