Plastic AC vent dropped into ducting
  • Plastic AC vent dropped into ducting
    I drive a VW Tiguan 2014, and made the common mistake of popping my air-con vent fins off the plastic bar that holds them together. I followed instructions on removing the dashboard trim, but unfortunately the plastic bar has already fallen into the air-con ducting (photos attached, red circled). 2 questions:
    1) Any chance I can disassemble this and try to recover the plastic bar? I assume the ducting leads to the air compressor?
    2) If not, can I still safely turn on the air-con? Any chance the plastic bar has fallen into delicate areas of the compressor and may jam up if I turn it on?
    Many thanks!
ID:	1869043Click image for larger version
    Try a vacuum cleaner and see if it will suck it out
      Thanks, do you think the strong reverse air-flow from vacuuming might damage or suck out anything else that I shouldn’t?
        bubble gum on a long straw?
