Hi all!!
I have been having a few problems since owning my 2000 T4 2.5 petrol AET!!
Mainly engine cutting out at traffic lights either the AC on!
After changing the PCV valve and pipe from there to the air intake, replacing both green and blue sensors, don't have the stalling issue!
The dramas i have now is the van coughs kn start up from cold, so I have to turn the engine off straight away!
If I restart the van it will fire up straight away no problem!
This is always when the van is cold!!
I have changed the fuel filter a few weeks ago but had the problem for ages!
Some Machanic mentioned maybe there is a faulty no return fuel valve in the fuel line somewhere!
Any ideas?
2. Second drama is the van hisses when cold with choke on as if there is an exhaust leak! It has done it since I owned it but got the exhaust checked out and there is no leaks, apparently the exhaust guy says all older VW that come in do the same , golfs Etc! Is this normal?
3. Noisey tappets!! Never had noisey tappets before I got my timing belts replaced but maybe that's just a coincidence?
I have tried MANY types of oil like Penrite , Nulon, castrol Magnatec, from 10W 40/30 to now fully synthetic 5W40 premium stuff but still quite noisey! At least noisey to me be be to some , I only hear it because it was super quite when I first bought it! Are they hydraulic lifters or can they be adjusted??
Any ideas?
