Hey dubbers!
Just joined, so please bear with me!
Vehicle Details: VW Transporter T5 tdi
Odometer: 278000
Build Date: 2005
Vin # WV1ZZZ7HZ6H008525
Engine# AXE046713
Trans Code and Type Box code: HGE
Purchased my 2005 Transporter TDI Dec 2014 - odometer reading: 258200 - I noticed that occasionally, especially during city/town driving, gear changes were very clunky was not at all smooth going through the low gear ranges. Then the serious problems started back in June 2015. The first sign of these problems, the vehicle would go into limp home mode. So decided to get the gearbox scanned, updated the software and gearbox oil changed. Which improved the low gear changes and overall gearbox performance for a short while.
But unfortunately after a few months of good running, the van started going into limp home mode again. Managed to get away with re-scanning and erasing fault codes, which worked for a few weeks. But this now does not make any difference and vehicle is not driving at all well. Seems to be constantly running in limp home mode, It will eventually go through the low gear range and If it does manage to get out of the low gear range and into 5th, 6th gear it seems to run reasonably well, responds to revving etc.
Last vehicle diagnostic/scan test result: Faulty shift solenoid, conductor plate
Basic scan: 2nd,3rd gear incorrect ratio
Any suggestions on the best way to move forward in sorting the problem would be greatly appreciated, seem to be running out of options! Have had a number of varying prices on used gearboxes and quotes on repairing the valve body etc. Both options seem expensive and potentially problematic? A number of auto specialists have suggested contacting VW direct as apparently, they now offer reasonably priced rebuilt/reconditioned gear boxes?
But after a number of calls and email messages to South Yarra VW Commercail centre, Melbourne and thanks to VW's level of customer service, I am still none the wiser on that query!?
One final question, this may be a case of wishful thinking! but If the box was low on oil or wrong oil used - could this potentially cause a problem? or could it be an electrical, sensor fault?
Let me know what you think.
Thanks in advance
Odometer: 278000
Build Date: 2005
Engine# AXE046713
Thanks in advance
