One of the issues I have noticed on my newly purchased 2006 T5 2.5 TDI (BPC) is that it has a faulty thermostat. The temp gauge only sits on about 50 instead of getting to 90 where it should be for normal operating temp (then sometimes after about 40 mins of driving suddenly jumps to 90).
The other (main) issue I've been focussing on is a clogged DPF with the usual Christmas lights on the dash - engine check light, DPF light and flashing glow plug light. My local independent VW guy did a quick check for me with VCDS to see if it was a simple fix as a favour but couldn't spend much time on it because he's booked out for 3 weeks.....
1 Fault Found:
008194 - particulate trap bank 1
P2002-000-efficiency below threshold - MIL on
Since, the car needs to run at 2000+ rpm consistently at operating temp for at least 15 mins to do a passive regen (according to the manual), would the faulty thermostat be preventing this happening and therefore contribute to my DPF problem? I've only had the T5 2 weeks so I don't know how long the PO has been driving it with this dodgy thermostat.
1 Fault Found:
