Hi all
just wondering if anybody has had a head gasket fail on an axe engine ?
A couple of weeks a go I got the low coolant level message, and sure enough the coolant was down a bit.
Topped it up , but a couple of days later the message came back.
This time there was engine oil floating the top of the coolant, not much but it coated the level probes.
Cleaned out the bottle, refilled and away I went.
Next day same thing, oil where it shouldn't be. A bit of searching on the web says the oil cooler will be the culprit, new one of those and new seals..... but the same thing after fitting.
Its possible that the new cooler is a dud but
So now im thinking head gasket ?
Its done 300k which is pretty good going I know, but I would like to fix it.
Mark
Mark
