I decided that I was sick of messing around with the adaptor lead for the trailer. Having identified backwards from the trailer the seven wires on the seven pin side of the 12 pin plug to the 13 pin round VW socket and thence in the main loom, I proceeded to make the same connections from the loom to the flat socket. I replaced the changeover switch embedded in the VW socket with a changeover switch mounted beside the socket on the vehicle. At first when I flashed it all up I got some weird goings on on the trailer lights so I took the car for a short drive with nothing connected and then tried it again. I now have tail/side lights, right hand indicator but no brake or left hand indicator. I have checked my wiring and have checked for voltage output on the actual loom but zilch. Could it be that I might have to have my ECU reset?
Any suggestions appreciated.
Many thanks
Peter
Many thanks
Peter
