T5 trailer plug hrlp
  • T5 trailer plug hrlp
    Hi guys,
    I FINALLY got around to putting a tow ball on the van (pig of a job, who ever invented the plastic push lugs owes me an hour of my life back!) and now i just need to organise a plug. I was told its not that simple on these vans, is that true? All I need is brake lights and indicators for when I pick up scaffolds etc on trailer. The van has zero fancy features like reversing sensors etc so is there a loom point I can splice into or a factory plug hidden I am unaware of?
    Any help would be really appreciated.
    Pre-'10 facelift, you can just splice into the tail light wiring.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Lol. I know your pain with them stupid clips!
      BRISBANE / GOLD COAST
        Perfect!! Never been happier to have the pre facelift
        Can anyone link me to a diagram of loom and recommend a splicing location?
          Yep, clearly a single use item if there ever was one.. Once I got a method sorted I could remove them all with no damage quite easily but the learning curve was quite aggravating!
            Just probe the back of the light connector with a testlight to get the wires you need.
            You'll need to run a wire over to the right-hand side for the right side blinker.
            '01 Beetle 2.0
              If I remember right you can tap into the drivers side indicator harness at the very top where the harness comes out of the rear pillar on the drivers side .
                Perfect thank you
