Cooked motor in my t5 2.5 deisel
  • Cooked motor in my t5 2.5 deisel
    Not sure how but the motor has gone in my 2005 manual high line. So what now? Has anyone got advice on replacement motors, or, does anyone want the van, everything else is fine, beautiful in fact.....not sure of the value.
    Did it get hot, or did it just milkshake?
      Cooked t5 motoror
      Initially I was losing water but did not where. Pressure test said there was not a problem. Continued to loose water so I took it to beetle exchange. They replaced the water pump, seemed to be running fine, 200 klms later oil warning light came on, I stopped, she never started again.......
        From what I have read the water goes into the engine , oil and water not a good combo . Judging by the short distance travelled after the pump was done it sounds like the answer .
          Just got a quote for around 10000 fitted for a used one . Looks like this is the way I am going......
            Have a 2004 T5 2.5 turbo diesel auto for sale only 150000 kays one owner , picture here http://www.vwwatercooled.com/forums/...sporter+photos
              So, my multivan is back on the road thanks to queanbeyan deisel service. New second hand engine with 70000,ks for $8000, new turbo, new starter motor, $12800 back on the road. I have to say the new engine is a lot more powerful, no lag, about 20% more power up the hills. I think problem all started when I was losing water straight to the oil sump, so when they did a pressure test, sure there was nothing leaking out. Even though we changed the water pump in the end I think the damage was already done. They could not turn the engine at all. The oil hydraulics had completely seized. So, as others have said the minute you start losing water, stop, and get it fixed.....
