From Wikipedia it seems you have a problem with some vegetation in your engine ? {A potometer is a piece of apparatus used to measure the rate of water loss from a plant (transpiration). The rate of transpiration can be estimated in two ways:}
1 of 2
2 of 2
Mystery noise from under the hood
It could also be a "photometer sensor" ?
Those familiar with the diesel exhaust emissions maybe know the word.
But, why not to call them and ask? The guy probably used a different term for something or just made a typo error.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Well here is a update.
I was refitted with my second EGR in as little as 4 weeks thanks to VW warranty on parts this was covered. After install techs still found check engine light on, they diagnosed faulty ECU. Asking VW for goodwill they supplied a new ECU and I just had to pay 2 hours labor. I was told a new ECU would have cost me $2900 if I was to buy one myself. Thank god I did not..
I now have my VW back and all seems ok, but I have not really had a much of a chance to drive it, because I have spent the last 3 weeks in hospital due to a busted appendix, and a laparotomy and other complications.
I sure hope this is the last of my VW issues for some time.
I like to think my dealer has looked after me.2011 T5 4MOTION Duel Cab Optioned up.
Well here's my under-the-hood burping/farting/buzzing sound fixed (at LAST!) - and what it took.
"...carried out diagnosis and found issue relating to tpi attached resonances on the boost pressure control valves; removed and replaced with vacuum hoses with updated vibration dampeners as required. Road tested all ok"
Parts ... VW7E0129458N ... hose $28.67
... VW 7E0129458M ...hose $42.95 The prices reflect, I believe, a part-warranty reduction.
LATE EDIT: don't know if it makes any difference but I should probably have stated that my van is a twin turbo.
Last edited by greymad; 11-01-2016, 03:04 PM.sigpic2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
Thanks for this info guys! My 2011 T5GP also has the mooing noise occasionally too ... I think once I even got the limp home mode too.
Interestingly looking under the hood, the large silver part of the engine where the oil filter attaches to has a sticker saying "Pierburg Cooler, manufactured 2013" ... but the car is 2011..... why would there be a 2013 part in there? Has this got something to do with the EGR valve?- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
My 04 has started doing this farting noise intermittently, most commonly on startups, or even just turning the key(no start).Sometimes just sitting at the lights.
Again, not always though.
Had a quick perusal around the vacuum hoses,etc couldn't see anything obvious.Even chucked some WD down a hose thinking it's a sticky valve.Still occurred again.
No loss in performance, no codes on my code-reader, vacuum EGR has been blocked long ago.
Not too bothered yet, until it gets worseSteve
04 T5
Originally posted by Rebuild View PostNot too bothered yet, until it gets worse- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
Originally posted by YellowLemon View PostLooking under the hood, the large silver part of the engine where the oil filter attaches to has a sticker saying "Pierburg Cooler, manufactured 2013" ... but the car is 2011..... why would there be a 2013 part in there? Has this got something to do with the EGR valve?
Links:
VOLKSWAGEN 03L115512, oil filter bracket with: Cart Part Info
VOLKSWAGEN 03L 115 512 (03L115512) Cooler, exhaust gas recirculation
Kühler, Abgasrückführung 03L 115 512 | 03L 115 512 A Kategorien 03L 115 512 | 03L 115 512 A Kraftstoffaufbereitung 03L 115 512 | 03L 115 512 A Abgasreinigung 03L 115 512 | 03L 115 512 A Abgasrückführung 03L 115 512 | 03L 115 512 A Kühler 7.02756.07.0
Car Part VOLKSWAGEN 03L115512, oil filter bracket with
Costs 800 Euro newbut it's on the front of the engine (engine code CFCA) doesn't look like it would be too hard to replace....
Although the air intake seems to go behind the back of the engine which is naturally where I'd expect an EGR valve to be, so I'm not sure what's going on. Will just cross my fingers and hope I have no issues.- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
Originally posted by YellowLemon View PostI just checked the part number for this part mentioned above on the front of the engine where the oil filter attached, it's 03L 115 512A and described as EGR VALVE online. So obviously this Multivan has had the EGR replaced in 2013, phew...
Links:
Sent from my HTC_0PJA10 using Tapatalk2011 T5 4MOTION Duel Cab Optioned up.
Originally posted by REVHE4D View Postto change this you need to take the whole front end off and dump the oil and coolant. It's a big job.
Seems like the biturbo CFCA engine has been getting 'new and updated' versions of the EGR valve every few months ... have a read of the thread above- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
