08 Multivan - antenna adaptor for aftermarket stereo
  • 08 Multivan - antenna adaptor for aftermarket stereo
    Hi all,
    I'm planning to install a Pioneer stereo into my brother in law's Multivan.
    Can anyone confirm which antenna adaptor i need?
    These are the two different types I've seen ebay.
    Can anyone please tell me which one of the two I need?
    eBay Australia: Buy new & used fashion, electronics & home d
    or
    thanks in advance.
    One last thing.
    Will i need to purchase a separate cradle?
    thanks again
    2006 B6 Passat Wagon 2.0 TDI
    RCD510, MDI, 9w7 bluetooth, Footwell lights, Door warning lights
    VAGCOM cable owner
    Totally depends if the current wiring is single or dual FAKRA in that van. Our 2005 has a different type again!
      I think you will find the cradle off the factory unit will fit the aftermarket one as most manufacturers have multipe holes to fit a variety of mounts . You may need to drill a couple of new holes in the cradle to get some holes to line up . I just read up on the Fakra system can be a bit of a bugger to work out which type as it seems that different VW models work differently . As a matter of interest I just finished a swap over in afriends T5 2012 model we used a Chinese brand double Din model with all the bells and whistles I used only one of the two connections as neither one seemed different in signal strength . The main issue with the chinese units are that the radios are Digital and as some of you would know reception of Digital radio is very limited as the stations do not want to spend money on repeater towers . Goes to show I suppose that the chinese are at least using the new technology even if it does have its shortcomings here in Australia ES878AU 7" HD Digital Touch Screen Car DVD Player GPS TMC DVB-T iPod VW MAGOTAN | eBay
        Bugger. It looks like the only way to be sure is to pull the headunit out and have a look.
        thanks for all the replies.
        VAGCOM cable owner
