Originally posted by Sharkie
View Post
T5 with DSG and multi function steering wheel question
And the airbag arrived today .... brand new as well. Awesome service from the seller in Portugal. Onto Jmac now to get it fitted ......
That is awesome !!!!Originally posted by IN2VWS View PostMine arrived today.....It is now fitted (easy job). It was plug'n'play.....no programming required. I am a happy chappy.
Did you have much trouble getting the airbag off? Any tips to share in doing this, as I'd like to get mine done this weekend (if its easy enough) otherwise Jmac can only slot me in on the 13th of August and the wait will kill me.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Airbag came off easily.
Here are some pics that might help.
It is recommended to disconnect your battery when doing this, but I didn't.
1. turn steering wheel 90 degrees. With the steering wheel adjustment, tilt the wheel all the way down and pull it out as far as it will go.
You will need a short screwdriver to lever the spring clips that hold the airbag onto the wheel.
Once one clip is undone, rotate the steering wheel 180 degrees, and do the same to the other clip.
Once this was done, I centered the steering wheel with the engine running (otherwise it was difficult to turn the steering wheel without the powere steering).
I then switched off the engine and removed the key, and let the van sit for half an hour (to make sure there was no power going anywhere (radio, dash etc.)
You will have to unplug the rectangular yellow plug from the steering wheel. To do this, you will see a white-ish part on the top of the plug. Slide this back towards yourself, and then he yellow plug will come out.
You will need one of these to get the steering wheel off:
Fitting is the reverse of what you just did.Last edited by Guest; 29-07-2011, 03:18 PM.
What size is that Hex key? I can't find 1 ..... Jimmy had to postpone my fitting so I'm going to have a go provided I can find a toolset like that ....Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
i wish you'd not posted that. I now want one. Even the wife would love it.. now question is...
in my van I have a rcd510 + touch BT kit. the phone button just mutes the stereo so not fully phone integrated. it's also a manual and I have no wizz bang dash display. If I get a wheel with the volume and phone buttons (on the left?) only, will it work with me van?
ta
I don't think it will work, as the wiring may not be there for it.Originally posted by T5Pete View Posti wish you'd not posted that. I now want one. Even the wife would love it.. now question is...
ta
Got my spline socket yesterday and installed the wheel today. Looks beautiful.
However, DSG paddles don't work yet. I knew it wouldn't as when we coded the RNS510, we specifically checked that the MF steering wheel option with tiptronic shift was not enabled on Vagcom. All the other buttons work perfectly.
I'll get that coded during the week. Will need to clear the a/bag error code as well, as I started the car without the a/bag plugged in and the error light popped up.
Update again when all completed.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Looks like my 103TDI MV does not have control module 16 - Steering wheel.
Can anybody with VAGCOM and a 103TDI do a module scan and see if module 16 - Steering wheel is there?
and for interest sake,
Can anybody with VAGCOM and a 132TDI do a module scan and see if module 16 - Steering wheel is there?
Need to play with Vagcom a bit more as initial quick checks had us clear the a/bag warning light no problems, but could not find the setting to enable the DSG paddles ....
Yes, both MFD and MF Steering wheel were factory fitted.Originally posted by IN2VWS View PostDid your van have MFD or a Multi function steering wheel originally?
My understanding is, if your van does not have these originally, the controllers and wiring will not be in place to retro fit them.
Also, in 02- Auto Trans, there is a checkbox with MF Steering wheel fitted = ticked.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Had a look thru my VCDS, and I cannot find anything to do with steering wheel paddles.
Here is my auto scan results which shows the coding for each installed module. Compare with yours, it might help.
Address 01: Engine (J623-CFCA) Labels: None
Part No SW: 03L 906 022 JD HW: 03L 907 309 H
Component: R4 2,0L EDC H30 7052
Revision: 22H30--- Serial number: 00000000000000
Coding: 01254012232400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20BTD01103L906022JD 002009
ROD: EV_ECM20BTD01103L906022JD.rod
VCID: 70E4613D1A33
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 045 J HW: 0BH 927 711 C
Component: DSG DQ500-7F H04 1408
Revision: 00H04V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VN75.rod
VCID: 3C7C850D06FB
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 708764AD89A90E9626A89176A96116
Shop #: WSC 02736 790 49152
VCID: 3668972538D7
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 AK HW: 7E5 907 047 AK
Component: Climatic-T5 H11 0203
Revision: 00005001
Coding: 0000000002
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaticT5_VN75.rod
VCID: 78F4591D7243
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 D HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0221
Revision: BO047001 Serial number: 0347 279100767
Coding: B8A0303A0E33203300280010342B8CD50080430F6004400030 0000000000
Shop #: WSC 02734 790 00000
VCID: 356A902925D1
Part No SW: 7E0 959 801 B HW: 7E0 959 801 B
Component: J386__TSG_FT 002 3311
Coding: 010000
Part No SW: 7E0 959 802 B HW: 7E0 959 802 B
Component: J387__TSG_BT 002 3311
Coding: 000000
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Coding: 830000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00B H06 0013
Revision: -------- Serial number: 003HL001TXX8
Coding: 000000000000000000000000000000003042
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 356A902925D1
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7E0 920 870 C HW: 7E0 920 870 C
Component: KOMBI H20 0220
Coding: 760B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_VN75.rod
VCID: 29524C59F969
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0221
Coding: 042300
VCID: F0E4E13D9A33
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7F0 035 680 HW: 7F0 035 680
Component: RNS-MID H42 2726
Revision: AB001001 Serial number: VWZ6Z7K5253046
Coding: 040002020200009000
ASAM Dataset: ------------------------- ------
VCID: E3CE9E715BC5
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: E3CE9E715BC5
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
Component: Telefon 007 0078
Revision: -------- Serial number: 35909603054464
Coding: 020000000100000000000400
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VN75.rod
VCID: 214254798159
End ---------------------------------------------------------------------
