I'm carrying a 6mm aluminium plate to put under the jack when (if) needed off road. I'm in the process of putting some pieces on the plate to minimise the chance of the jack sliding sideways or backwards.
Through the base of the jack, centrally but toward one end, there is a black nylon protrusion (about 10x25x4mm). (Far end in the attached photo.) On the upper side of the plate the nylon fitting clips onto the jack pivot shaft.
Can anyone tell me what that nylon part is for? That it protrudes suggests it may be to increase friction with the ground. This seems a bit pussy but I can't really think of what else it might be for.
I need to know so I know how to handle it when finishing the plate.
Ideas and comments welcome.
Thanks folks.
Dave
Oh, FWIW. I found out last year that when goats jump into a T5 they can cause $10.5K damage as they die.
Thanks folks.
Dave
