Hi asking for a friend he has a 2012 T5.1 2 litre turbo and has a water leak around the diesel cooler on the front of the engine . Has anyone changed one and what sort of job was it to do . Thank You .
Diesel oil cooler
looks like an auto water/oil trans cooler. My advice, get rid of it, and replace with an air/oil cooler. It's an auto trans heater. Your auto oil runs at best, 90C. I converted to an auto air cooler after the gearbox was rebuilt at 160K( seals/ o-rings had gone hard due to oil temps IMO, damaging gearbox)
On the T5 the long flat diesel cooler is under the vehicle behind the passenger seatLast edited by Rebuild; 29-04-2024, 07:46 AM.Steve
04 T5
Yes that was on my older T5 under the car directly behind the wheel which goes off road first , ours got punctured leading to diesel spraying out onto the road causing the van to do a great version of a drift racer when we turned onto a main road . We didn't see it was leaking until then , next morning just fitted a bypass hose and all was good .Originally posted by Rebuild View Postlooks like an auto water/oil trans cooler. My advice, get rid of it. It's an auto trans heater. Your auto oil runs at best, 90C. I converted to an auto air cooler after the gearbox was rebuilt at 160K( seals/ o-rings had gone hard due to oil temps IMO, damaging gearbox)
