Hi all,
First real post on here so go easy on me
I picked up a 2013 Multivan TDI400 (cfca) a few weeks ago with a dsg issue very cheap. Plan is for it to become a weekend camper for me and my partner once it's hopefully fixed up.
I'm waiting for a vcds box before I tackle the dsg so for now I've turned my focus to the engine. It's done ~250k KMs so hoping the EGR cooler hasn't done too much damage (wish I'd googled that before buying it). I drove it home 60-70kms on a uvp with no real issue aside from the dsg not wanting 6th gear, engine felt strong.
Upon further inspection I found a lot of oil on everything but particularly bad at the timing end of the top of the motor. Pulling the timing cover off revealed a lot of oily grime around the main camshaft pulley and the hpfp. I'm hoping this isn't a Hpfp fault as the oil doesn't smell like diesel, suspect it's tracked down from the top of the motor but confirmation would be appreciated.
The rocker cover gasket was changed last September so unlikely to be that, cam seal is my next guess.
I cleaned the motor down well so hoping I can track the fresh leaks now....
Does anyone have any other suggestions for how I can narrow it down further?
Pics aren't the best but oil definitely starts above the HPFP.
Thanks in advance,
Jordan
Thanks in advance,
Jordan
