Seeking any assistance in Perth with timing belt fault after change. Will run limp mode only Dtc 001600. Home expert or commercial. Thanks in advance
Need help Perth with t5 tdi timing belt change fault p001600
Who installed the new timing belt? That error suggests the engine is out of time, meaning its been installed incorrectly.
Best case scenario your camshaft sensor or crankshaft sensor has failed, otherwise the timing belt has been installed incorrectly.Last edited by Lucas_R; 28-07-2022, 11:42 AM.
