Hi All,
Recently bought a 2007 T5 with the 2.0L (AXA) engine.
Pretty bad oil leak so started pulling the inlet manifold to see whats going on seemed to be leaking from the area under there.
Found what can only be described as a hole. Need to pull off the bottom part of the inlet manifold to verify, but looking on parts diagrams it appears I'm missing whatever #19 is on this parts diagram.
The part numbers and descriptions stop at 18 for some reason.
Anyone familiar with what this is. Looks like it should just clip in. Not sure whats happened for it to be missing, but the car still runs just with a rough misfire under load.
