2.0TDI Engine - EGR cooler failures
This is a sticky topic.
  • 2.0TDI Engine - EGR cooler failures
    A lot has been posted on internet in past few years. I hope this post will help some owners.
    High engine oil consumption, unexplained coolant loss, engines prematurely worn out are the topics often posted in this section.
    Leaking EGR cooler will damage your engine and cause high oil consumption, even completely destroy your engine slowly or very fast, if you do nothing.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
    Impact of internal coolant leak on engine.
    The coolant leak that isn’t external means that the coolant is leaking into the engine ; either the oil, exhaust or(and) intake side.
    Coolant leak into the engine oil - quickly degrade the engine oil and such contaminated oil is no longer suitable for 15,000km service interval - excessive wear occurs.
    Changing the engine oil and filter at 1/2 intervals obviously extends the life of the engine and may delay failures. It also explains why some owners are lucky enough and their engines last even when there’s a coolant leak into the engine.
    Slow EGR cooler leak into the part of EGR cooler where only exhaust gases should be cause the coolant to get sucked into intake and into the cylinders where in a short time causes cylinder walls pitting, rusting, where in the small cavities created, engine oil that would under normal conditions be wiped down into the oil sump by piston rings, stays and burns in the combustion process.
    A small amount of coolant in combustion will not cause any immediate problems for the engine. The engine may even have slightly more power, because of steam. That’s very generally said. But, in the longer run, it will reduce the engine’s life and cause other problems.
    Larger amount of coolant entering via failed EGR cooler will hydro lock the engine and cause immediately no start. If the engine hydro locked partially, the results could be connecting rods bent just slightly and the piston(s) no longer run true in the cylinders. The engine may still run reasonably or poorly. Such engine will have a lot of metal particles in oil as result of pistons scraping cylinder walls on one side.
    Anyone with an unexplained coolant loss should get their engine oil analysed, it is inexpensive and can save you lot of money in the long term, (DIY is possible).
    You may even claim a new engine from VW Australia.
    USED OIL ANALYSIS | PRODUCTS | CASTROL AUSTRALIA
    Some tips;
    Make sure you use UOA (Used Oil Analysis) kit from a reputable/recognised organisation.
    Make sure that you always collect detailed paperwork when you had any warranty work done by your dealer, no matter how friendly relationship you have with them.
      Reserved space
        Any T5, T6 any 2.0TDI Amarok, Golf 6, Golf 7, Passat, Tiguan etc. that has a high oil consumption or needs new engine, because of the engine is prematurely worn out, has probably legal right to request repair or compensation from Volkswagen, because of poor design of the EGR system.
          I bought this subject up with my independent VW mechanic , his opinion was that removing the parts may affect the temperature the engine runs at . His thought were that VW build the engines to run at particular temperatures and changing that could cause issues with certain components going outside the design parameters .
            A bit off topic but...
            Removing of the EGR is also illegal, so we won’t discuss it in here. After all, we’re law obeying citizens here, living in the cities and want to truly protect our health.
            A bit of history about the EGR.
            First it appeared around the hippies time in 1970’s.
            Maybe they’re so excited about smoking the weed, that when someone was high, he got an idea to make his engine to swallow it's own smoke. Ever since the manufacturers were/are pushed to use more and more EGR and the EGR coolers were introduced maybe some 15 years ago, to handle that increased amount.
            So, quick answer to whether it’s needed or not. Is no, it’s not needed. Though the engine ECU runs the EGR and will look for it if you remove it. You’d have to tap into the ECU, to make it to forgot the EGR. The hardware can’t be just removed/blocked off.
            May be some climate fanatic could tell us, how much pollution is voided, how much less impact our engines (that are high on EGR) have on the environment, minus all the energy and resources needed to produce extra engines and parts to repair failed vehicles.
            Oh, and if the one wants to be really accurate, don’t forget all theses cars once the EGR/emission system is failing or failed are still in use often for a very long time, sometimes years before it gets repaired/scrapped and they will produce many times more emissions than if they’re designed without it. So, think about that too.
              Thats a great question, generally that type of research is a Life Cycle Assessment (LCA) and measures the environmental impact of a product across all stages of its life, and often weighed up against alternatives, or no action at all. Could be worth looking into and whether the automotive industry would have funded such research.
                Most of the research is done to prove something and most likely steered towards the outcome they want to achieve. In other words, it could be rigged.
                Sent from my iPhone using Tapatalk Pro
                  Question on this,
                  The EGR valve in my 2010 T5.1 failed in 2013 with around 40k on it. Replaced under warranty
                  Have just had the warning light for this come up again at 180k and Local VW says it’s the valve and cooler needing replacement.
                  What is the lifespan for these parts? Been quoted 1500 by dealer to repair.
                    Originally posted by Foxpuppet View Post
                    Question on this,
                    The lifespan of EGR coolers varies greatly. Some fail at 30,000km, some last over 100,000km and anything in between. I'd probably go with an aftermarket part rather than genuine.
                      Considering a 2016 T6 Camper with 42K on it. That's not many Ks for a 5 year old diesel. It has a full service history. I am leaning towards new but am attracted to the savings and lack of waiting time offered by the second hand one.
                      Given the issues reported above, and in particular it seems this vehicle has either been sitting around or a lot worse, doing short trips, what about simply biting the bullet and getting a new EGR filter and cooler fitted and figuring that into the overall cost, or do you think that's a bit over-cautious. TIA
                        My T5 had an EGR change @ about 280k (I think) and might be due for another one @ over 400k.
                        The 2018 Crafter seems to blow them every 140k.
                        2018 Crafter Runner
                        2012 T5.1 6sp manual.
                        2024 Crafter Auto
                          Anyone have ane experience with the $200 egr valves on ebay?
                          Where does one find the OEM part no. for your particular model?
                            I own a 2011 Tiguan 2.0 Tdi... It used 2 litres of oil with a recent (2400km) trip... Most of that oil ended up on my trailer behind the vehicle
                            I've been under the vehicle and removed the belly plates... The oil seems to come from somewhere behind the engine, under the DPF... This is where the EGR cooler sits... The leak does not seem to come from the turbo oil supply/return lines...
                            Could a faulty EGR cooler cause this amount of oil leak? I did not use/loose a drop of coolant, just oil...
                            For me to try and pin point the leak, I will need to remove the DPF, which is a HUGE task (drop sub-frame and remove driveshaft)... And only then I would be able to see what parts I need...
                            If I know for sure it could be the EGR cooler, then I could buy one before I start to strip...
                            Vehicle has 185k km.
                            Any suggestions as to a replacement EGR cooler ?
                              Hi My T5 Engine number is CFC064572 on the ERG plate has an A at the end and mine is the twin turbo 132Kw MY12 model. Is that still classed as a CFCA motor?
                              Thanks Nick
