DSG 2nd to 1st Bang
  • DSG 2nd to 1st Bang
    Hi Dubbers,
    I have a 2013 Multivan auto diesel, done 530,000k's. Gearbox was slippping so put it in for new clutch and mass flywheel, $3500. Since getting it back clutch is not slipping anymore, but, drives perfectly 2nd to 7th gear and back down, then as you pull up when it shifts from 2nd to 1st....Donk heavey shift, anyone had this before?
    Its been into VW dealer who said they cannot read with a diagnostic tool, back to the garage who did the clutch twice, sent it out to auto transmission specialist to redo the Metatronic base settings and its same same? Am I looking at a rebuild, if so can anyone recommend a reliable company?
    Any help would be greatly appreciated.
    Flipflop50.
    Can't help with the auto, but how has your engine performed over the years?
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
      Can I ask who did the first round of jobs , just a suburb to save specific companies from getting bad reviews .
        Originally posted by flipflop50 View Post
        Hi Dubbers,
        Flipflop50.
        Do you have any performance chip box hooked up to your engine? If yes, try disconnect it.
        Performance Tunes from $850
        Wrecking RS OCTAVIA 2 Link
          Multivan gearbox donk
          Brendale
            No mate
              Brilliant, serviced regularly still use it but the 2nd to 1st donk is annoying,
              I get around it by knocking it into neutral before it gets down to second gear. Engine seems as strong as ever.
                Fair innings, all things considered.
                The gearbox isn't right. Will probably need a new Mechatronics.
                '07 Transporter 1.9 TDI
                '01 Beetle 2.0
