Hi all - we are currently replacing a worn cam on our 2006 multivan (2.5 TDI AXE).
Its going well, BUT the cam looks 180 degrees out.
We are using the special tool (aftermarket kit from Germany) and Haynes manual for reference/torque values etc to set the crank and cam at TDC, however, when its all set up, the cam lobes on no.1 (i.e. driver's side) are pointing down. This has my father (a retired mechanic) confused as he is used to having the lobes point up and out (V shape). Makes sense as it closes both valves.
I have little mechanical experience, but it also goes against what I can find on www.
Apparently the tools can only fit in one way - which from our experience is seems to be the case.
So what is going on here? Any help appreciated.
