Originally posted by heyasam
View Post
Hi again Heyasam, you can SAFELY use a wet cell battery and do not have to vent it to outside the cab.
Being as you are in NSW, this is legal ( it is actually only illegal in VIC ) so you could save some money.
But as posted earlier in this thread, you can only use up to 60% of a cranking battery if you want to avoid shortening it’s life span. It would also require that the battery must be mounted upright and this may limit the sizes available that will fit under your seat.
Alternatively, you could use an AGM or Lead Crystal battery and because they can be laid on their side, you will be able to fit a bigger battery.
There is also the advantage of not needing as big a battery. By this I mean, for example, if your were considering a 100Ah wet cranking battery, you would only have 60Ah available, while an 80Ah AGM will give you the same available Ah and a 55Ah Lead Crystal battery will also give you 60Ah of usable capacity.
All just food for thought!
