I haven't played with a 2.0l Polo GTi yet, but so far every other Gti and R (Golf and Polo) that I have played with simply have different boost curves to give the required power and torque. When I match the boost curves they make the same power and torque. For example add back the missing 2 to 3 psi of boost to a 169/350 Golf and they make 180/370, the boost curves match. Add ~4 psi to the 180/350 and they make 200/400 same as adding another 4 psi (making 6 to 7 in total) to the 169/350 and they make 200/400 exactly the same.
Not saying that there aren't other differences but most of the power and torque differences come from the original boost levels. Which, provided the turbo handles it, can be tuned over.
The Brudack cycle is simply camshaft timing, which changes with rpm, for example the early closing of the inlet valve doesn't happen at higher rpm. Has no real impact on power or torque.
Gary
Gary
