yep spot on - That's the long term plan. I just had to get it in cos I was starting to stress that I'd get a defect for the pod. I couldn't even do pedestrian speed gearchanges without whoosh bang diverter valve cycles that sounded like a BOV and big induction noise. I had a patrol car next to me the other day and it was so hard to drive it without incriminating noises.
yeah I'll do a short 90 degree aluminium tube bend off the TIP (I may have to cut the TIP a bit shorter) and then line up the filter for a straight shot from the CAI fitting above the radiator. The MAF will move with the airbox though. The MAF inlet is 70mm OD but with the MAF screens etc the MAF intake ID is 62.5mm. If you just put a 70mm ID hose over the MAF then the incoming air will be mangled as it goes over the outside lip/step of the MAF and could cause some metering dramas potentially with all the turbulence that would make. The way it is at the moment the airboxes stack ID closely matches the MAF ID (oversize by about 1.2mm di) so that's the best place for the MAF to be.
I also need the MAF to be distanced upstream of the TIP because I'm going to run pre-compressor water injection at some stage. Its boost pressurised nozzle will be welded into the aluminium bend that will go prior to the TIP. You cant have water running through a MAF or so close to it that reversion could get at it from behind which is another reason for the MAF to move to the front. Like you said there's plenty of room now so I'll get the water reservoir mounted as far back as possible probably to where the airbox is now. What I'm not certain of is whether or not I can run the water reservoir any lower than the nozzle position so I'll have to put a bit of thought into how I map all that out. Plenty of bench tests to happen first though and the WI may not even go in until after I sort which turbo i'll run with.
Yeah when you look back at the before pic its just so much better now with less weight, what weight that remains has moved back and low and you can actually get your hands into various spots in the engine bay that wouldn't have been possible before. I do feel a little bit warm inside about it but that will wear off and then I'll get onto the next thing I'm sure!
