Great to see the progress. I've not had issues with the bolts coming loose. Just use the recommended bolts and gasket.
I'm curently of the position that they come loose when they get over tightened. They require very little torque, like 28 pound foot or something if I recall. They're a stretch bolt so just need to stretch with elastic deformation.
Yeah if you're not redoing the tune I'd run the 7psi spring. Though if you're retuning I'd be cranking up that spring rate to 3-5psi below what you're planning to boost it at (e.g 15psi spring). I'd had done this had I known of this stuff at the time.
