Spent bits of time today fitting the new battery up to a tray that I'd roughed out that needed some finishing touches and deciding on amd bending up the hold down clamp etc. Battery is a Full River HC20 that's going to be fitted as pictured lying on its side down low sort of underneath where the OEM airbox is. The shape of the tray will make more sense once its fitted but its going to be bolted at the front of the tray to the two posts coming up off the gearbox mount and at the top to a point just below the ABS module/assembly.
Once that's in i'll have to switch over to a pod style filter that'll eventually either draw air from a partition at the front of the engine bay where the battery used to be or perhaps through the factory airbox again if it can be modified to fit. dunno about that bit yet.
