Hey guys,
having another minor issue with the polo, sorry ive been absent from here of late but with a mortgage, the funds to mod the polo are goneskis, and lets face it you lot don't help me with wanting to mod and upgrade her.
Anyway the story is as follows, car developed a rattle coming on boost. Got worse, took it to vwvillage, who said the flex join in my downpipe was rattling.
So I took the car to hitech mufflers and had a 3" stainless downpipe with 200cel cat made up,
Car drove like a dream the boost comes on harder (19-20 psi in first, never used to do that!), no rattle on the drive home. An hour later sitting hot, and bam the wastegate started making the same noise again.
It is worse in the shorter gears, and ive noticed it seemingly comes and goes once you've been driving a while. Seems less of an issue in 5th rolling on at 80.
When I unplug the n75 the noise doesn't seem to happen, and equally the car only boosts to about 5 psi (dunno if that's limp mode or if its just the maximum the turbo can boost without the n75 routing pressurised air to the actuator.
Im guessing its either:
a) a cracked vacuum hose from the N75 to the wastegate actuator, not enough airpressure to close the wastegate, and hence the rattle
b) faulty N75 (was replaced in 2013)
c) wastegate actuator issue (could be the actuator itself, or the rod has come loose)?
d) the internal flap in the wastegate has crapped out and it is somehow flapping around?
Anyone with an profound ideas? Ive had a vagcom scan run on it, and no boost/wastegate relevant issues were detected..
was contemplating replacing the n75 again, but don't want to waste time or money if its something else or something one of you guys has any experience with.
Hope someone has some insights.
Ben
Ben
