17" wheel/rim size for a 2007/2008 Polo GTi
  • 17" wheel/rim size for a 2007/2008 Polo GTi
    All
    Can someone please tell me if the following wheel/rim size is suitable for a 2007/2008 Polo GTi?
    17x7.0 +35 5x100
    Thanks in advance
    They should be fine.
    The offset is a little low for my liking (I'd prefer closer to 40) but people who like "poke" have run with less.
    Resident grumpy old fart
      They will stick out 9mm further than the standard rims.
      What size tire do you plan to run?
        Was hoping to put Bridgestone Potenza RE002 tires on the rim.
        From what I read on the "Polo tyre" thread, either 215/40R17 or 205/40R17 seems to be the two choices?
          The 215 will probably rub the front guards unless you get them rolled. The 6R guys have a bit more room under the arches.
            Thanks guys.
            I already took the risk and bought the rims yesterday.
            I called a couple of tyre shop today and told them I have 17" rims for my car. One shop asked me for my existing stock tyre size and he said the 205/40 R17 will be the best fit for my car but this tyre is apparently less common than the 215/40 R17 and hence costs $20 more per tyre.
            I am in Perth so I think there isn't a lot of tyre retailer choices for me? K Mart Tyres and Bob Jane are the two retailers I have called. Does anyone else knows what other tyre retailers in Perth carry Bridgestone tyres???
              How did you get on here, did 215/40 work fine on those rims? I've got a set of rims the same specs, but the jury is out on the tyre size. Probably wouldn't mind going 205/45 r17 if it'll work with my h&r springs.
                I run 205/45 R17s with my H&R springs. They clear fine and are a nice fit, fill the arches really well
                2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
                  Sweet! Do you think the speedo is a bit pessimistic now? I think standard they're like 10% optimistic on these cars.
                    I don't think so. Although I haven't ever really tested it. Put it this way, if I go past speed cameras bang on the limit, I don't get pinned for speeding so it can't be to far out even with taking the speed buffer allowance into account..
                      I went with 205/40 R17 Potenza Adrenalin RE3 tyres and they certainly fit fine with plenty of clearance.
                        For the money I would do the front strut brace over the front swaybar.
                        Can go past good tyres for handling, recently put PSS on the front of my S3, was such an improvement compared to going to KW V2's.
                        215 needs some offset accuracy when lowered.
                        Dont make the Polo too stiff of low if you have to take bad roads at speed, not worth the pitching IMO.
                          What offset are your ones, do you know? I've now got two sets of 17x7s - one at ET35 and the other at about 41, by my measurements... Thanks.
                            Mine are +40
                              I'm not sure of the offset of the Audi TT rims, but I run a 215/45/17 semi slick on it, no scrubbing on bumps, only a very little if/when going full lock right.
                              The speedo is out about 8% with standard tyres, it's less with the 215/45's, but still out. More like 3-5% at 100kph. That's measured with my lap timer. With the daily 17's, it's still ~3-5% out. Can't recall exact figures, but still on the safe side to have the speed a bit over 100kph and not exceed the posted limits.
                              Daily: 2010 VW Jetta Highline
