LCA bushes, who's using what
Red ones should be NolathaneOriginally posted by louis19 View PostAfter Gav changed a few things on polo last weekend he noticed my LCA's were ones he nor I had seen before. They're red, unlike others purple or yellow ones. Not sure on brand as they weren't installed while I've owned the car but it's definitely not the standard ones as Gav said. Anyone else have red ones or seen them for sale? Just curious which brand they are
06 Polo TDi
Im having axle tramp and i have the Pedders LCA bushes which i think are the same as the Whiteline ones, they are currently around 3 years old, I doubt they would be failing already.
Maybe i should change to the Superpro with the anti-lift ?
Can camber contribute to axle tramp ?MODS- TOO MANY
I've had the superpro ones in for a month or so. Installed in the anti lift position.
They were done at the same time as the vibratechnics mounts so there is a definite increase in cabin vibration, mainly through the steering wheel but it's not bad, just everything feels nice and tight. Once 'run-in' I only really notice the increased vibration when coasting off the gas and even then it's only through the steering wheel a little.
Cornering is a bit sharper, not a faster turn in or anything just more defined in the cornering.
No axle tramp to speak of so far though I'm only running stage 2 so YMMV with more power. I've ripped up a few nice double pegger skids and it was rock solid the whole way.
I'm happy with them.08 9n3 Polo GTI
Mods: heaps
Hoyhoy.
Greg, there's one problem that I have with Powerflex & that is from past experience.
It would take a lot of convincing for me to try them again.
Hooroo.
Seat cupra R solids, simple. now seeing cars over 100k, fitted them back near 30k still as good as when I fitted them. Will outlast the car im sure. But not a simple slip in like the the other mentioned, press in $288 sup and fitted with stretch bolts etc. I still import these folks
Pm but don't come much so check out sig, mobile is there
Ta
Jmac
ps If Seat don't last 60k plus ill eat my hatAlba European
