The same offset super pro bush will do either anti-dive/anti-lift or castor. Its the same offset bush kit used in either set up. Its how you fit it that determines the geometry you get.
For anti-lift you fit the eccentric portion vertically down. This tilts the wishbone down quite a bit at the back. It does this so much so that I could barely get the new front LCA bolt through at all as I'd machined up tighter tolerance centers for bushes.
For castor you fit the eccentric to the outside of the bush console ie 90 degress around toward the hub from the anti-dive position. As Stuwey said this forces the ball joint forward giving more castor.
I had wondered if it was possible to fit them between the two positions ie 45 degrees around from the anti dive position to get the best of both worlds but didn't want to be a guinea pig on such a prick of a job.
