Looks like you still have std manifold Eddy? this one has a big throat ATP and the trouble with that is the inside bolt which is mainly the offender has a stud instead of bolt and its stretched and with the bigger manifold access is nil really . The bolts are 75mm as opposed to your 50mm bolts. Don't worry its back f ing tight and a duralok nut for now. Have to say mind I did have the bolts wirelocked with its last turbo and as far as I know it never came loose, wouldn't know its had a bit done since then. With its application now essentially the turbo needs to be taken off or dropped heaps for a new bolt or indeed a new Stud. I cant agree more with a bracket mod mate, at the end of the day its vibration and heat that's the cause and the puny wee bracket they have doesn't cut it. Ive seen normal untuned bolts loose so its not only happening to the ones that get thrashed.
Jmac
Jmac
