SEAT Ibiza ?? Cupra Air Intake
  • #31
    Hey guys just bought one off guy for 160 it was like 5 mins to fit and simple as will take it for a fang soon and let u know how it goes
    Originally posted by seangti
    • #32
      Hoyhoy.
      I'm curious
      Hooroo.
      • #33
        yeah jason let us know what happens
        For Sale 2006 VW Polo GTI
        Have a Look
        CUSTOM CODE
        Phase 2
        • #34
          Originally posted by Wand Weaver View Post
          Remember though that the K03 is only a small turbo - and there's only so much it can do without doing a K03 Sport or K04 turbo upgrade.
          Hoyhoy.
          Any chance of clarifying about the KO3 Sport, would like to know more about it.
          Hooroo.
          • #35
            From what ive read better air flow and able to handle higher boost 15lb. Is this right?
            Have a Look
            CUSTOM CODE
            Phase 2
            • #36
              The 03s holds boost a lot better at the top end compared to the 03. There was one fitted to my Leon Cupra which I had up to 140mph indicated after it was chipped. There was some more to come but I ran out of road/bottle.
              A pretty cheap upgrade if your 03 died, I would go for one otherwise. Also you would need different software to get the most from it.
              • #37
                Hoyhoy.
                Thanks bud.
                Hooroo.
                • #38
                  Originally posted by Eddy View Post
                  Hoyhoy.
                  The K03 Sport is a modified version of the K03. This article (relating to the Passat 1.8T) explains what the differences between the K03 Sport, K03 and K04 Turbos are.
                  • #39
                    Very interesting article ...
                    http://www.greedspeed.com/articles/a...Spring%2C+1999
                    Thanks for pointing that out, WW.
                    Cheers,
                    Dave
                    • #40
                      cmon jasn78 - every1's anticipating!
                      • #41
                        I was told we had the k03s in our Polo's... i guess not then
                        • #42
                          It is a KO3 ...
                          What gives you the impression it's not?
                          Dave
                          • #43
                            Guy might be able to tell us more as he has had his one off. this is the info off Project polo on vortex posted by guy.
                            K03 - 82 is the turbo that came off - its an 06A VW partnumber - so it does not cross over to any other VW's that I'm aware
                            From what im reading the K03s varient usually on the 1.8T that has 180hp (polo gti cup maybe). Nots sure so please correct meif im wrong.
                            Have a Look
                            CUSTOM CODE
                            Phase 2
                            • #44
                              I'll get the part number off a stock turbo if you can find out if its a K03 "Sport" or not - people in the industry dont refer to it as such - its a term that has developed on the forums from what I understand!
                              Part Number K03/82 710006962 (last bit is probably the serial number)
                              • #45
                                Dave
                                As far as I'm aware, the 110KW/150hp spec 1.8T came with the K03, whilst the 130KW/180hp spec 1.8T comes with a K03 Sport.
                                There's every chance the different turbocharger is the difference between the Polo GTI and Polo GTI Cup edition - rather than a simple reflash.
                                If Guy or Seb has a spare turbo or two lying around from a conversion - they might like to compare the two. From research (never eyeballed the things) - the K03 Sport should have a larger housing and impeller wheel.
