Originally posted by Funkdancer
									View Post
Polo Problems & Fix Register
	This is a sticky topic.
You can cancel cruise with the cruise control on/off switch. When you push it not all the way it does a cancel while remembering the previous speed. Push it till it clicks into the other position and it turns off completely and forgets the speed.
Anyone else ever needed to top their coolant up?
I've found that - after nine months and approximately 6000km, I've hit "Low". No warning lights or anything, and no visible leaks in the system that I can see. I'm going to have to get a bottle of G12+ and a bottle of distilled water, and give it a bit of a top up.
I had a low coolant light come on just before my 30k service. The guys at the dealership didn't seem too worried that the car was loosing coolant somewhere.sigpicOriginally posted by KaiAnd then dont forget the most important mod for gays.
Blow off valve - 300
I am pretty certain there's only one reservoir. Given it takes a while for the fluid to come out at the back, I'd say it's just the one.Originally posted by PeterHBne View PostAnyone know if the rear wiper fluid is from the same reservoir as the fronts? Can't find a rear reservoir so I'm guessing it's a yes.
Also, I've never had a car with two reservoirs, I always thought all cars just use the one?
I had this too but happened every 5000k and took my car in the vw ro find a hair line crack in the radiater all fixed under warrenty.Originally posted by Ben_GTI View PostI had a low coolant light come on just before my 30k service. The guys at the dealership didn't seem too worried that the car was loosing coolant somewhere.
Anyhow, picked up some G12+ and a bottle of demineralised water (yes, I'm being pedantic!) yesterday afternoon. I'll be monitoring this pretty closely - I suspect it might be something to do with me getting stuck in absolute gridlock last weekend (roadworks) for about half an hour, if not more.Originally posted by PoloGTi View PostI had this too but happened every 5000k and took my car in the vw ro find a hair line crack in the radiater all fixed under warrenty.
My seat squeeks and the back passenger side brake caliper sticks so the car squeeks when I first move off and when I turn corners.sigpicOriginally posted by KaiAnd then dont forget the most important mod for gays.
