VAG-COM Logging
  • #31
    Originally posted by insanekiwi View Post
    REVO tune seems to be quite aggressive with boost. Same with mine, peaks at 22.3psi briefly on recent dyno. And also seems to produce quite high power production at wheels. This is a good constructive thread, please keep it going. I have VAGCOM, just haven't had time with the car recently...
    Is it just me or is that an arse load of boost??
    • #32
      Originally posted by Guy_H View Post
      Thanks I was going by this before, wrong info
      MODS- TOO MANY
      • #33
        That should work too. You just log exactly what you want rather than what VCDS pulls up. Try it any way, there may be some difference??
        • #34
          WHat my whole problem was, that I was going off the info on the APR site.
          It tells you to go to Advanced Metering Blocks, which is what I cant do
          Im sure I can do it the other way
          Might go try soon
          Thanks for the cable tim lol
          MODS- TOO MANY
          • #35
            what troy is trying to say is that the advanced section is greyed out on his car. He only has access to just the normal measuring block section so needs to put in the number instead of ticking a box.
            FOLLOW US ON FACEBOOK
            • #36
              That ECU in the APR screen shots is an MED9 I reckon, maybe that has something to do with ADV blocks not being available?
              • #37
                yyyyep. The above APR link is fine just not applicable to Troys car it seems.
                He should be fine to do it the other way. Given he isnt online at the minute maybe he is out in port melbourne somewhere trying to wind out 4th gear
                • #38
                  Are there sections of non-public tarmac out there or a really big Macca's carpark?
                  • #39
                    Haha Just went out to get food
                    Lots of traffic around here on a sat night
                    MODS- TOO MANY
                    • #40
                      What version of the software are people using, I noticed on the site there are many options people can download
                      MODS- TOO MANY
                      • #41
                        409 for mine, if your using the USB type, Think you need the next one up.
                        Have you connected to your car? Can you scan codes? If not, you still may need to be working on the drivers...
                        • #42
                          I have scaned it and cleared all the codes
                          Still trying to work out the logging
                          Some of the things look different on the screen on the version i am using
                          I am using the 908
                          MODS- TOO MANY
                          • #43
                            Ch 115 only gave me this
                            09:55:09 Group 115
                            720 /min RPM
                            20.3 % Load
                            1010.0 mbar Absolute Pres.
                            09:55:09 Group 115
                            760 /min RPM
                            20.3 % Load
                            MODS- TOO MANY
                            • #44
                              yeah... thats what you want... then you need to log it as you drive...
                              This records the same info, but over time, then you can graph it!
                              • #45
                                I've installed the FORGE TIP and made some more logging:
                                so here's boost before and after the tip
                                BLUE - before the TIP
                                ORANGE - after the TIP
                                So, with the TIP only the requested boost seems to be higher all over the rev range
