K04 - Which one and how much?
  • K04 - Which one and how much?
    Don't tell my wallet, but as I've done most of the other required mods, thought I should see how much a K04 is.
    So, I believe the K04-001 is the one used in conjunction with the APR tune?
    Can a different K04 be used with the APR tune?
    I'm seeing K04's for about 250 - 300 pounds, which would be somewhere around $600 landed, obviously I'd need to make sure they are legit, is there something I'm missing here?
    Is installing a new turbo a big job (for a mechanic)?
    As I know, the K04-001 is the most "popular", because it's a bolt-on replacement of the K03s.
      get Dom's T3 and get some REAL hp !
      EDIT: and custom code that shiz!
        Fitting the turbo isn't that hard, you need to take the right driveshaft out to make it much easier to access.
        Don't kid yourself into thinking it's a cheap upgrade, unless you can do it yourself.
        I thought APR had K04 software that was free/cheap. It'll work on the std software but certainly won't be running at it's best.
        To truely get the most out of it, you need to emulate hardware of the K04 equipped factory cars, like the 8L S3.
        pogo55 has one, I reckon APR fitted it in Brisbane.
          Beware of Chinese turbo's, can not Guarantee the result with those - buy a genuine Borg Warner KKK K04.
          Talk to your nearest APR dealer about software upgrade!
            Have you looked at the APR site
            I think if you supply all your hardware, turbo etc they charge you about $700 for the software
            It you buy the turbo etc from them the software is free
            Do you need a new manofild or does it bolt straight on
            Can someone tell me how much power you would get over the K03 with the same mods, exhaust etc 40hp??
            MODS- TOO MANY
              I was at a dyno day where a polo had DP, Intercooler, APR K04 with software and it pulled 169 HP atw on a Dynomatics dyno in non shoot out mode. Hope this helps!
                i think dats alittle low for a car with k04
                  That's what it made on the day though. It has standard MAF and injectors.
                    As I said NON shoot out mode
                      there is only about 10kw atw and 20NM in a K04 over a worked K03 car ..... APR's Red Polo was doing around 150kw atw where some K03 Polo's have been doing 140kw atw with all the stuff you need for the K04 anyway ....
                      Don't bother ... its not worth the extra $$$ you'll be spending ...
                        What about something from
                        Based in Chesterfield, Derbyshire ( United Kingdom ), JBS has over 20 years experience working with VAG vehicles, being awarded Audi Driver Magazines
                        Looks like they have modified hiflow turbos that bolt to standard manifold
                        MODS- TOO MANY
                          if your going to do a turbo comversion, do a decent one... GT28rs!
                            Same old issue that you reach a point where you are paying thousands of dollars for a few kWs. For a road car or even weekend cruiser, I just can't see the point in a K04, maybe on a race track, but once again the issue of traction in a Polo is the limiting thing, hard to get all those wild horses to the ground.
                              Dyno's are also only good to compare a stock car on the same dyno, the same day.
