Originally posted by DiZzY
View Post
Radiator Leaking
Originally posted by russ83 View Postold thread just realised....
but... my polo had this leak 1mth OUT of warranty, cost me 900bucks... fail... I reckon the dealer waited to tell me this...
JmacAlba European
Originally posted by Vdrink View PostMy GTI polo 2006 radiator is leaking on 40,000kz, I see this is a common problem..does anyone know what causes it and how much it cost to replace?
aus liebe zum automobil
I have no warrantyI bought the car second hand 10 months ago. I had a racv report done they said it was in mint condition but when I took it for a service they said my radiators leaking. My mechanic said labour would be around 300 to replace it + 300 for the radiator.
Mine has started leaking at 40000.
I bought it end of 2007 so 6 months out of warrantydamn...
Too many reasons to not like this car anymore
Rattle pisses me off
Constant Air vent having a mind of its own PISSES me off..
Radio losing its mind or not reading cd's
Sunroof opening by itself..
And now leaking radiator
within 6 months 2 people backed into the car denting it(no $ to fix )
Selling time
Originally posted by Allegiance View PostHi Guys,
I notice the coolant light comes on every so often, don't know if the radiator is leaking or not though. Is this what occurs for you guys?
I notice the coolant light comes on every so often, don't know if the radiator is leaking or not though. Is this what occurs for you guys?Originally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
If coolant light comes in it is most likely a coolant leak. You won't see any leaking on the floor, but if you get under the car and have a good look at the radiator you should spot it. Get the dealer to look at it regardless (it is a common problem) and at least if they dont find anything they will have it recorded in their system so if it becomes obvious out of warranty you have a leg to stand on.NickZ
Former ride: MY07 Black Polo GTI
Current: MY09 Blue Passat R36 Wagon
Happening to me as well. The same symptoms. Radiator light started flashing more and more frequently. Originally happened probably a year ago, but dealer said there was a pressure vacuum... they did something and it fixed it for a couple of month, then started happening again. Didn't think much of it.
Finally, did a check up before warranty ran out at a different dealer, still nothing, but they did replace my radio head unit. Found out about 3 months ago that I need a new radiator, and I'm out of warranty since last August. In the mean time, I've gone through about 2 bottles of coolant... =(sigpic
'07 CW Polo GTI
'Roof::Leather::Tint
GIAC::Whiteline RSB + FSB::Forge SB:ogbone
Glossy B::Cubby::Honeycomb::Antenna
Cygnus - if you have a full dealer service history and noted coolant issues during your warranty period, you may find the dealer will honour the problem, particularly as they are a known problem on the GTI.NickZ
