Originally posted by VWindahouse
View Post
Porsche Brakes
That's craziness with the warping rotors.Originally posted by SoVeReIgN View PostR32 brakes are also an option. (S3 = 312mm, R32 = 334)
FYI - Going for brakes thare are too big can cause a problem on such a lightweight little car. I have warped my R32 rotors because apparently the car doesn't weigh enough to heat the whole surface of the disc under normal driving. Only a section of the disc ever heats up causing it to become uneven (ie - warped)
I haven't taken in through the mountains or to the track yet so right now i'm wondering why I even bothered, the standard brakes do quite well considering.
I suppose with the big block weighing the front of my car down plus the added weight of the Haldex system negates this effect in the .:R. I mean that front setup did come off the W8 Passat originally.
Cheers,
Trentsigpic
Yeah my A3 weighs ~1200kg vs what 1500kg for the R32??Originally posted by Treza360 View PostThat's craziness with the warping rotors.
Cheers,
Trent
1477kg is the official stock weight for the MkIV. 1510-1530kgs for the MkV.Originally posted by SoVeReIgN View PostYeah my A3 weighs ~1200kg vs what 1500kg for the R32??sigpic
Audi Roadster is 1470kgs.
My OEM brakes weigh 35kgs so im interested to see how much weight isave with my Porsche brakes being alloy vs the cast solid metal the OEM ones are.2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
