That's not too bad for a 2 pot upgrade then. Please disregard what I said for a single pot U/G then
Porsche Brakes
Originally posted by seangtiThe price of the car rarely indicates driver ability/lap time.
I know a member on here who's put 355mm 4 pot Porsche brakes on his MKIV GTI, $1700 with calipers, lines, pads etc...80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Have you been able to source a brace? I'm very keen......Originally posted by JCM308 View PostWhen I get a little closer to being able to do the upgrade Guy is definately someone I'll be talking to.
I think 6 pots are a little overkill. A nice set of 4 pots should do the job. Worst case scenario I'll look at the Brembo package but for the time being I want to know what the other options are like. From the info i've been able to find the Porsche option seems to be the most cost effective.
You can always get a master cylinder brace to stop the firewall flex.
R32 brakes are also an option. (S3 = 312mm, R32 = 334)
FYI - Going for brakes thare are too big can cause a problem on such a lightweight little car. I have warped my R32 rotors because apparently the car doesn't weigh enough to heat the whole surface of the disc under normal driving. Only a section of the disc ever heats up causing it to become uneven (ie - warped)
I haven't taken in through the mountains or to the track yet so right now i'm wondering why I even bothered, the standard brakes do quite well considering.
so i've heard! i've also heard the discs tend to wear out before the pads on some occasions because the Polo GTI pads are designed for spirited driving.Originally posted by SoVeReIgN View Postthe standard brakes do quite well considering.
I'm happy with how fast mine pull up and they are completely standard, fluid and everything. If i was to do anything, it would firsty be to upgrade fluid and braid the lines.
That's where you'll notice the difference.Originally posted by SoVeReIgN View PostI haven't taken in through the mountains or to the track yet so right now i'm wondering why I even bothered, the standard brakes do quite well considering.
The quote I remember is "They'll stop you really well, once."
If you don't get what that means it is - they aren't really up to track use or the like, but do a great job in general use.FOR SALE
"VW GTI" QLD Prestige Plate
did this just happen to the fronts or the rears only?Originally posted by SoVeReIgN View PostR32 brakes are also an option. (S3 = 312mm, R32 = 334)
im trying to work out what the advantages of upgrading your rear brakes was?
i got these:
hope i dont have the same problemLast edited by XXX-1.8T; 06-02-2009, 11:57 PM.2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
They're massive, what size wheels are you running???Originally posted by XXX-1.8T View Post
I find the standard brakes ok with the Ferodo pads but I do some "Spirited" driving through the Royal National Park in Sydney as well as Maquarie Pass fairly regularly and even with a standard car the brakes really aren't up to scratch. That's why I don't mind spending a reasonable amount on new brakes because I can't put a dollar value on my life!!!!!!Originally posted by VW GTI View PostThat's where you'll notice the difference.
Those brakes are awesome. Are the prices on the website in US$? How much you paying for freight?Originally posted by XXX-1.8T View Post
For what it's worth, I went for the APR Brembo 323mm upgrade and after fitting the right pads I can't see that I need anything more in the brake department than that.
This is in a car that spends a reasonable amount of time as a street car but gets (ab)used regularly on the track at both social and competitive events, including driver/co-driver events where the car finishes one track session only to swap drivers and go back out again.
The pads that came with the Brembo kit weren't up to the use they were getting - after every track day I had to have the discs machined to remove the pad material that had melted onto the disc. After testing with an IR thermometer one day (35º at Wakefield) and finding the discs were above 650º regularly, we swapped to better pads and haven't had a problem since.
There's not much weight in the Polo which certainly helps braking performance, but after some hard laps of the track the current APR/Brembo setup on my Polo wipes off speed as well as my other cars that do have Porsche brakes - so my advice would just be to stick with the 'easier' brake upgrades (APR/Brembo, S3, R32 etc) and save yourself some money and hassles.
