Personally, I liked the playing of Black Sabbath and then Pearl Jam in the background until road/motor noise took over
Meet my Polo!
Yeah I just checked out the vid and it performs awesomely and you don;t seem to be having any grip issues at all. I love that track. Looks awesome and very fast. What sort of top speeds can you get upto on that? Looked pretty fast to me.Originally posted by Plautos View PostIn the beginning making turns with the second gear was very hard, I was loosing traction, the car was over steering, but the track have a good grip, so I had to adjust me to the problem. I had to control more the throttle, pumping it or going slower.
I don’t know the car 100% yet. I need to practice more. Fix some suspension and brake issues.
But in the end, traction is not a problem, the car have a good grip after all.APR V2 Tuned, APR Dogbone mount, APR R1 DV, K&N Panel Filter, SEAT Intake, Forge TIP & FSB, Bilstein & H&R, Whiteline RSB, Full Milltek 2.5" exhaust
My top speed was 210km/h at 110m to the first leg of the S.
Hit the brakes, go to 80km/h to make the turn.
This is very interesting.
Ok.. Just to clear everyone thoughts..Originally posted by insanekiwi View PostWow... impressive... very very.
Can you please put your mod-list again with uptodate info?
Oh yeah and the videos were cool, but human camera mount gave me motion sickness
Engine:
Hi flow exhaust manifold,
RS4 CHRA turbo, K04-25, mounted in a machined K04-01 compressor housing.
Forge FMIC and TIP,
K&N 3004 air filter,
N75Race,
0280156063 fuel injectors TT225,
NGK spark plugs PFR7Q,
Moroso crankcase evacuation system.
Exhaust:
3”Downpipe to the Stock catalyst,
2,5”Catalyst to the end.
Suspension:
H&R Springs
Wheels:
Center Line, Storm. Light weight 18x7
Tires:
Yokohama Parada 215x35 R18
Brakes:
Wilwood Forged Superlite 4 pistons;
14”Rotors;
Eletronics:
APR k04 software.
I’m running with 95oct fuel.
These infos I found on the net when I was researching turbos. I don’t know how precise they are, but I know they are very close.
The Turbos.
Their specs are as follows as compared to a regular RS4 K04.
compressor wheel RS4: 40mm inducer, 51mm exducer
compressor wheel RS6: 42mm inducer, 56mm exducer
K03
That turbo had a compressor wheel with the following dimensions:
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
The K04-001 compressor looks like this:
Inducer: 35mm
Exducer: 50mm
Tip height: 3.7mm
The K03-052 (K03S) compressor is a bit larger still:
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
The K03S is saddled with a tiny turbine:
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
compared to the K04 turbine:
Inducer: 50mm
Exducer: 42mm
Tip height: 6.4mm
Blades: 11 => MY k04-25 TURBO HAS 12 BLADES!!!Last edited by Plautos; 18-02-2009, 10:12 AM.
